8" speakers in front eg civic
Old Feb 2, 2006 | 08:45 AM
TORQUE MONSTER's Avatar
Default 8" speakers in front eg civic
Anyone fit an 8" 3 way speaker in the door of an EG civic? if so piccs please? Or was it a good fit?
Old Feb 2, 2006 | 11:32 AM
B18C_EJ8's Avatar
LOL!!! I'm sure it can be done, but there's no way in hell there's going to be enough depth in the door, unless you never want to put the window down again... You'd have to build custom door panels to create the depth required to mount that speaker...
I have, however, seen installs with 8" subs in the kicks in custom pods....
Old Feb 3, 2006 | 12:29 PM
Sex Cells's Avatar
Default Re: 8" speakers in front eg civic (TORQUE MONSTER)
dont listen to this complete retard. yes, it can be done. you'll have to create MDF baffles. just make sure to deaden the **** out of it and you should be able to get a TON of midbass. what speakers are you thinking of going with? DLS?
Old Feb 3, 2006 | 12:40 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to this complete retard. </TD></TR></TABLE>
Hey douchebag... Did you happen to read my post where it says "I'm sure it can be done"??? Didn't my post cover building custom mounts?
Besides.... I'm not the one asking about an eight inch 3 way speaker!!!
Old Feb 3, 2006 | 01:53 PM
Default Re: (B18C_EJ8)
WHAO WHOA, now you're attacking me? Whats wrong with 3 way 8" speakers if thats all i'm gonna have? BITCH!
Old Feb 3, 2006 | 01:59 PM
B18C_EJ8's Avatar
I've just never seen 8 inch 3 ways before... The only thing I came up with when I googled them were similar to these:
Nor have I ever seen an eight inch 3 way speaker mounted in a car before.
Old Feb 3, 2006 | 02:25 PM
LSRracing95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I've just never seen 8 inch 3 ways before... The only thing I came up with when I googled them were similar to these:
Nor have I ever seen an eight inch 3 way speaker mounted in a car before.</TD></TR></TABLE>
there are actually 8 inch 3-way component sets.
dynaudio makes a set with 8 inch woofers, 3 inch mid-bass and 1.1 inch tweeters.
i was just introduced to these.
probably makes for great imaging and staging.
original poster, make sure to amp the set and also add a nice woofer to your system as well
Old Feb 3, 2006 | 02:35 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
^^^^ ditto that, I heard a set of three ways like that before. The sound is killer. but so is the price.
Old Feb 3, 2006 | 02:59 PM
Sex Cells's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Hey douchebag... Did you happen to read my post where it says "I'm sure it can be done"??? Didn't my post cover building custom mounts?
Besides.... I'm not the one asking about an eight inch 3 way speaker!!!</TD></TR></TABLE>
well dumbass, you dont know what you're talking about because A.) you've never even heard of an 8inch woofer, let alone a 3 way setup. and B.) you suggested he fab a WHOLE NEW DOOR PANEL
should've shot yourself in the foot while it was in your mouth
hey torque, what set is it?
Old Feb 3, 2006 | 03:30 PM
Default Re: (Eugenics)
Lets get this straight and cleared out before the bashing begins. Yes they do make 8inch 2 and three way systems. But there is a catch. Most companies don't make them. Why, Because most cars if not all do not come with 8 inch coxail. But here is a catch. If you want them you can get them. But Most will be home audio look below
Now if you want to get theses to work you are goind to have to do some wiring because most home audio is 8 ohm. I carry theses above because My vendor also carries mad home audio. Theses set alone is going to set you back almost 350 bux. Theses a kevlar speakers by pro-sound. Eugenics I never seen in anypost that b18 said that they made them or heard of them. Lets get back to helping people instead of bashing each other on someone elses post that needs help. More heads toghter will help this guy out rather then all heads bashing each other. Just my 2 cents.
Old Feb 3, 2006 | 05:16 PM
Default Re: (wrx-killer-Sti eater)
ditto.
and for the sake of sound staging and imaging.. if the car for the audio is right for a component 3-way setup.. by all means. get it.
dynaudio makes a killer setup with outboard crossovers, but as wrx killer stated.. these are VERY pricey.
i picked up a set of JL Audio 3-way XR's for 275 at my price, but they will cost the ordinary buyer in the neighborhood of 600-700 dollars.
as i stated before.. you should add a woofer to this system.. originial poster, what are your thoughts?
and eugenics made a good point by just making MDF baffles instead of fabbing new door panels. it will overall be better for the deadening of sound you dont want, easier to make, and much more stealth and clean looking in my opinion.
im much more of an SQ guy rather than make it as loud as possible and have "crazy" installs. because it just sounds stupid and a waste of money to me.
others have their own opinions though.
what ARE your plans as far as the set of speaks you want to install?
Old Feb 4, 2006 | 10:35 AM
Sex Cells's Avatar
Default Re: (LSRracing95)
heres what i was thinking
http://www.dls.se/english/index.htm
i've got a set of the 6.2's
Old Feb 4, 2006 | 11:00 AM
EBP_SI's Avatar
first let me start off by saying coax's are gay. if you're going to get any speakers for the front they should be components. second. Sure you can fit an 8 in the front door, but you're going to have to not only make new MDF baffles and cut some sheet metal depending on the shape of the basket, you're also going to have to re make part of the door panels. The other fun part will be getting the proper airspace for the 8" in the door. I'd suggest building an AP enclosure for them.
It can be done, i've seen it before. just dont think its as simple as making an MDF baffle screwing it in and you have a ton of midbass.
Old Feb 4, 2006 | 12:43 PM
fcm's Avatar
fcm
Old Fart
Read my sig. nothing is impossible........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to this complete retard. yes, it can be done. you'll have to create MDF baffles. just make sure to deaden the **** out of it and you should be able to get a TON of midbass. what speakers are you thinking of going with? DLS?</TD></TR></TABLE> You need to STFU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">WHAO WHOA, now you're attacking me? Whats wrong with 3 way 8" speakers if thats all i'm gonna have? BITCH!</TD></TR></TABLE> You need to take another toke off that joint in your avatar, B18C_EJ8 was the first one to post an answer to your question and he gave good advice, Eugenics was not only being a rude dork, his advise of "you'll have to create MDF baffles" and "just make sure you deaden the **** out of them" is probably just a little on the simplistic side.
I am also sure that B18C_EJ8 remark was not directed at you.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Besides.... I'm not the one asking about an eight inch 3 way speaker!!!</TD></TR></TABLE> but at Eugenics for asking what kind they were, and if it was directed at you it was only because an 8" speaker for the doors is strange enough, but there are not many of us here who think a 3way speaker is any more then a gimmick, [a 3way component set is a diff. matter] so I doubt he ment anything more then it was strange, it's the first one I have seen, and searching I find no other mention of an 8" 3way in the door.
As you can see from the rest of the posts, they are consistent with what B18C_EJ8 recommended and I also agree, it can be done but it will take a fair amount of custom work, not only for the speaker mounts themselves but the door panels and as EBP_SI points out, [and I agree, and I hardly ever agree with him] mods will have to be made to the sheet metal of the door also, [which in my opinion may be a mistake unless more work is then done to reinforce the area of the door that is cut out.
So have a toot, and don't snap back at people that are trying to help, if you had called me a "BITCH" I would have told you where to go in no uncertain terms. 94
Old Feb 4, 2006 | 01:58 PM
Sex Cells's Avatar
Default Re: 8" speakers in front eg civic (fcm)
well fcm, since you know everything why dont you explain it better. because you see i've already installed a set of 8 and 7 inch drivers. go play in your ******* JL shop and shut the expletive up because thats obviously how far your knowledge goes. most car audio drivers are IB, and your door is hardly an air tight enclosure.
until you actually know something that extends farter then your shop, shut the expletive up. you're probably just another half *** installer that sits in the shop and talks **** on everything he is ignorant to. and there is nothing gimicky about a 3 way component set. common sense should tell you he's not talking about a coax speaker. how many 8 inch 3 way coax's are there? get back in your shop bitch
also, i have yet to have to add sheet metal to a door
Old Feb 4, 2006 | 10:08 PM
Default Re: 8" speakers in front eg civic (Eugenics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote">well fcm, since you know everything why dont you explain it better.
first off, i believe in other threads, recently actually.. i told you to do just this. EXPLAIN YOURSELF. lets not be hipocrits here.
secondly.. fcm mentioned the fact that a single 3-way "coaxial" is a gimmick, COMPARED to a 3-way set which he went on to mention was a different story.
you continuously fail to read things and just get your ******* panties in a twist
Old Feb 5, 2006 | 09:17 AM
Sex Cells's Avatar
Default Re: 8" speakers in front eg civic (LSRracing95)
and who the expletive are you to tell me what to do?
yeah, well when someones bashing me im not going to lend much more to them other then a mouse wheel through their post.
Old Feb 5, 2006 | 09:30 AM
EBP_SI's Avatar
i think everyone needs to calm down and have a group hug.
Old Feb 5, 2006 | 09:54 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote">well fcm, since you know everything why dont you explain it better. because you see i've already installed a set of 8 and 7 inch drivers. go play in your ******* JL shop and shut the expletive up because thats obviously how far your knowledge goes. most car audio drivers are IB, and your door is hardly an air tight enclosure.
until you actually know something that extends farter then your shop, shut the expletive up. you're probably just another half *** installer that sits in the shop and talks **** on everything he is ignorant to. and there is nothing gimmicky about a 3 way component set. common sense should tell you he's not talking about a coax speaker. how many 8 inch 3 way coax's are there? get back in your shop bitch
also, i have yet to have to add sheet metal to a door</TD></TR></TABLE> Well if the over 30 years that I have been an installer has taught me anything it is that here you are the compleat retard, you jump in open your big yap and quickly stuff your foot into it, common sense tells me when someone says .....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">an 8" 3 way speaker </TD></TR></TABLE> he means exactly that, a 3way speaker.
And as has been mentioned you also open that yap without reading the post, I never said 3way components are gimmicky on the contrary I specifically said......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> [a 3way component set is a diff. matter] </TD></TR></TABLE> can you read?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote">also, i have yet to have to add sheet metal to a door</TD></TR></TABLE> Again, not reading, I said nothing about adding sheet metal to the door........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">As you can see from the rest of the posts, they are consistent with what B18C_EJ8 recommended and I also agree, it can be done but it will take a fair amount of custom work, not only for the speaker mounts themselves but the door panels and as EBP_SI points out, [and I agree, and I hardly ever agree with him] mods will have to be made to the sheet metal of the door also, [which in my opinion may be a mistake unless more work is then done to reinforce the area of the door that is cut out.</TD></TR></TABLE> You say, you have "yet to have to add sheet metal to a door " so your saying after you cut sheet metal in a door to accommodate an 8" speaker, you do nothing to reinforce the cut out area? Yea you know a lot more then me about installing and your knowledge obviously extends much "farter" then mine does.
Once you pry both your feet out of your mouth, feel free to respond with more of your trash talking, and lay some more of your vast knowledge about car audio on us, there is nothing I like more then to find posts like yours, print them and post them at work, and even enter them in our company newsletter under dumbest things you read. 94
Old Feb 5, 2006 | 12:16 PM
Sex Cells's Avatar
why bother, you work with jl stuff, you know everything. i'd kinda like to know where the expletive i said i removed sheetmetal though... that would be interesting. should've shot yourself in the foot while it was in your mouth
Old Feb 5, 2006 | 02:23 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote">why bother, you work with jl stuff, you know everything. i'd kinda like to know where the expletive i said i removed sheetmetal though... that would be interesting. should've shot yourself in the foot while it was in your mouth</TD></TR></TABLE> Still not reading are you, I never said you did, I was agreeing with someone else about the possible need to cut sheet metal to install an 8" speaker and all I said was IMO that was not a good idea unless it was the reinforced, your the one the said you have never installed sheet metal, [again spuing before reading].
What would be more interesting to see how you installed an 8" speaker without cutting sheet metal, foots back in your mouth, keep it up this is great stuff. 94
Old Feb 5, 2006 | 02:28 PM
Sex Cells's Avatar
You say, you have "yet to have to add sheet metal to a door " so your saying after you cut sheet metal in a door to accommodate an 8" speaker, you do nothing to reinforce the cut out area? </TD></TR></TABLE>
are you stupid? you keep talking ****, reinforcing it only with mistakes you've made in judgment/reasoning
whats so hard to ******* grasp? the driver used on the 6.5 and 8 dls, and 6.5 and 7 dayton rs are the same. same size etc. so all the mdf baffle has to do is give enough room for the basket to clear. inch, inch and a half. there is usually more then enough room. so its hardly a problem at all. THE MOTOR/DRIVER IS THE SAME SIZE ITS NOT A GIANT FEAT TO FIT IT, **** try installing the new xxx mids, thats more of a challenge then most 8's
keep digging yourself a whole
Modified by Eugenics at 9:27 PM 2/5/2006
Old Feb 6, 2006 | 12:53 PM
fcm's Avatar
fcm
Old Fart
Modified by Eugenics at 9:27 PM 2/5/2006</TD></TR></TABLE> Well that would be a diff. story.... if you had said you have never cut sheet metal in the door to install a speaker, but you didn't did you, you said "I have yet to have to add sheet metal to a door", in response, [I assume] to my agreeing with someone else, that installing 8" speakers in a door would require cutting sheet metal not installing sheet metal
You also said....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote"> common sense should tell you he's not talking about a coax speaker. how many 8 inch 3 way coax's are there? get back in your shop bitch </TD></TR></TABLE> As I said before common sense tells me when someone says 3way speaker they mean 3way speaker and when they say 8" they mean 8" not a 6.5" or 7" that someone calls an 8", now I can even understand a 6.5", a 7", and an 8" all using the same magnet size even the same VC size, and mounting depth may also be the same, it's done all the time, but the basket will be bigger, so common sense tells me you need more room to mount it, so cutting may be needed, and yes I have installed 7" and 8" and even a few sets of MB Quart 250mm 2ways in the doors of cars, and I have had to cut sheet metal on almost all occasions and reinforce the cut area. So common sense tells, that when somebody suggests that sheet metal may need to be cut, appearance tells me to agree and to caution not to do so without reinforcing the cut area.
Then out of the blue, you pop off something about never having to have to add sheet metal to a door,
So who is the "complete retard", "well dumbass"? or are you just "stupid, your the one that started with the name calling so if you can't take it stop, handing it out.
Your nothing more then an E thug with no more brains then to start a post by calling someone a retard, [who wasn't even talking to you but trying to give someone else some help] somebody calls you on it and your response is more name calling and crying because someone is "bashing you" grow the expletive up, and as first posted, "You need to STFU" nuff said, reminder to myself put Eugenics in the ignore file, along with all the other E thugs, but file under crybaby.
Old Feb 6, 2006 | 01:47 PM
Sex Cells's Avatar
im the e-thug, but you use nothing more then ignorance and ackronyms to address people. your feet have been so deep down your throat that you know no better. you're an elitist and can't even make sense of your own posts. but its alrightk, you're some 40 yearold with nothing short of a pathetic life crying on forums because someone tells you whats happening. so okay, lets role play. i'll go back to being the "e-thug" and you can be my bitch
i remember little bitches like you in kills, always backing yourselves into corners
Old Feb 7, 2006 | 03:39 AM
Here is a little qoute my father gave me its good advice This is not being directed at anyone, The people who need it ,know who they are.
" It's better to be slient and thought a fool then to open your mouth and remove all doubts"
