Pre-heat manifold before welding?
Old Feb 2, 2006 | 08:20 AM
meanEG's Avatar
Default Pre-heat manifold before welding?
just wonder and getting worried about warping the flanges when i weld the runners to the head flange and inlet flange. would it help pto preheat with a torch or oven prior to welding to prevent warping, or at least minimize it?
i am using the bmc race flange on the head. it isnt crazy think and it is cut on the inside i guess for heat disapation?
Old Feb 2, 2006 | 10:33 AM
onefstek's Avatar
Default Re: Pre-heat manifold before welding? (meanEG)
just weld it bolted down to a head, and then let it cool down by its self, still bolted to the head.
Old Feb 2, 2006 | 05:20 PM
discrete's Avatar
I think BMC only makes 1/2" flanges. It's not that easy to warp them so just be careful with the heat and you'll be fine.
Old Feb 2, 2006 | 06:32 PM
.RTErnie's Avatar
Default Re: Pre-heat manifold before welding? (onefstek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">just weld it bolted down to a head, and then let it cool down by its self, still bolted to the head. </TD></TR></TABLE>
exactly. I would suggest torquing it to the head. let it cool til its room temp.
Old Feb 2, 2006 | 07:15 PM
meanEG's Avatar
Default Re: (discrete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by discrete &raquo;</TD></TR><TR><TD CLASS="quote">I think BMC only makes 1/2" flanges. It's not that easy to warp them so just be careful with the heat and you'll be fine. </TD></TR></TABLE>
it doesnt look .5" and its undercut on the inside. i did not measure it though
hondaboy4life
Welding / Fabrication
Feb 28, 2007 08:26 AM
Ninja Mike
Jul 13, 2006 11:32 AM
BEEYOND
Jan 26, 2006 12:45 AM
philipwight
Mar 9, 2005 10:19 PM
Optiks.
Nov 27, 2003 12:29 PM
