car wont start...
Old Feb 1, 2006 | 08:14 PM
GreenEHDriver's Avatar
Default car wont start...
hey out there, i just bought a brand new starter for my 95 cx hatch and it wont crank or nothing. i get no noise, i can push start the car but its a pain. i had to buy the a new one b/c, i was chilling in a parking lot and i had the car turnned of and, when i went to start the car nothing happened. i ended up towing the car back to my place. anyway i NEED HELP PLEASE?!?!?
Old Feb 1, 2006 | 08:15 PM
Leb_CRX's Avatar
Default Re: car wont start... (GreenEGDriver)
make sure you have a good ground
make sure you have power going to it
if you think it's a bad starter, hook it up directly to the battery and see if it jumps out/spins...if it does, then your wiring might be bad, and you will need to trace it
GL
Old Feb 1, 2006 | 08:19 PM
96-EJ6 B18C's Avatar
Is the large wire from the batt to the starter hooked up? How about the small starter signal wire?
Old Feb 1, 2006 | 08:20 PM
thanks for the info... ill try that b/c pushing it sucks
Old Feb 1, 2006 | 08:21 PM
ts all hooked up do you think its maybe a fuse or something?
Old Feb 1, 2006 | 08:32 PM
It's very possible, I can't remember if or where the starter signal fuse is. Just start pokin around I'm sure you'll come across something.
Old Feb 1, 2006 | 08:49 PM
Leb_CRX's Avatar
Default Re: car wont start... (96-EJ6 B18C)
I am thinkign the black box under the hood
but I'm not sure either
GL
JPerkMr954
Jun 9, 2013 08:51 PM
Nathan_volcom
Aug 26, 2012 10:17 AM
ThaSpitefulWun
19
Oct 5, 2004 12:14 PM
Bbasso
Apr 6, 2003 12:02 PM
