JL Audio 12W7 ??????
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Real good speakers, They play real loud and tight. But be ready to she out some cash. A good amp and that sub is going to set you about a grand. Depending were you get it. Plus you need to get good cable and power wire to run the amp. If you a budget cheak out the mtx 9500. I use theses everyday and they are worth every penney. The cost is a little under the jl sub. check the out at http://www.mtx.com. If not you will not be dissappointed with the jl.
opps check out this link, http://www.mtx.com/caraudio/headtohead/w7.cfm
amazing SQL drivers, but not worth near retail. Check out a RE XXX
also found this auction, http://cgi.ebay.com/ws/eBayISA...15678
beyond inhumans are amazing, i personally heard this one, he won his class.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics »</TD></TR><TR><TD CLASS="quote">amazing SQL drivers, but not worth near retail. Check out a RE XXX
ditto. GREAT SQL woofer, large output, but not worth the sticker price. it hurts to shell out that much money on a subwoofer alone, then have to buy such a powerful top end amplifier to run it.
get a 12w6. good freq response and sounds great in a small sealed box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NLINE UNLIMITED »</TD></TR><TR><TD CLASS="quote">Are these Subwoofers any good? Worth getting? Let me know everything you know about these Subs.
Thanks Chris</TD></TR></TABLE> You know this is a 750W rms sub http://mobile.jlaudio.com/prod..._id=9 A very good 750W sub,
This would be a good amp http://mobile.jlaudio.com/prod...d=221
Alpine MRD 1001??
94
Alpine MRD 1001??
94
Bought my 13in With the Prowedge box for 600 off of kidd_drastic on H-T and I never regretted it
Make sure you dynamat your car or it'll sound like tin cans rattling. The feeling of your hair vibrating is the best.
I was running a Rockford Fosgate 500a2 bridged. This amp was underrated and probably pushed it 700w all day. But I just upgraded to the RF 1100a2 and the birthsheet says total watts is 1396.
But I'm in the process of custimizing my trunk myself so when it's all done, we can battle since we are both in OC.
I'll probably be done with it in like 2 weeks or so.
aww dam building a monster, well let me run to my lab, two weeks its on. lol, na I not going to freak this one off, I leave that to my other day, this is just a 9500 12 in the mtx box nonething special, lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XaznkewlguyX »</TD></TR><TR><TD CLASS="quote">Bought my 13in With the Prowedge box for 600 off of kidd_drastic on H-T and I never regretted it
Make sure you dynamat your car or it'll sound like tin cans rattling. The feeling of your hair vibrating is the best.</TD></TR></TABLE>
Yea im Dynamating the Entire 98 4Dr Blazer. Kinda more into Sound Quaity. If i just Dynamat the Rear, itll be a whole lot tho. Im goin to be Running two Alpine MRD-M1001s and One Stinger SP1000 Battery plus the OEM under the Hood
Make sure you dynamat your car or it'll sound like tin cans rattling. The feeling of your hair vibrating is the best.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XaznkewlguyX »</TD></TR><TR><TD CLASS="quote">Bought my 13in With the Prowedge box for 600 off of kidd_drastic on H-T and I never regretted it
Make sure you dynamat your car or it'll sound like tin cans rattling. The feeling of your hair vibrating is the best.</TD></TR></TABLE>Yea im Dynamating the Entire 98 4Dr Blazer. Kinda more into Sound Quaity. If i just Dynamat the Rear, itll be a whole lot tho. Im goin to be Running two Alpine MRD-M1001s and One Stinger SP1000 Battery plus the OEM under the Hood
Do you have any info or links for the MRD-M1001 amp I can't find any mention of it at Alpine Tech Support, they do have a MRC-M1005 a 700W rms into 4 ohms mono block amp, [05 model]
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Do you have any info or links for the MRD-M1001 amp I can't find any mention of it at Alpine Tech Support, they do have a MRC-M1005 a 700W rms into 4 ohms mono block amp, [05 model]
94</TD></TR></TABLE>
My amp it self was rated at 1087RMS.... they come with a Check Sheet
....... but heres some info about the 1001
http://www.alpine.de/alpine/cm...glish
http://www.dealtime.co.uk/xPF-..._Amps
http://www.cbrstereo.com/brows....html
http://www.bassjunkies.com/?pid=30593&rf=dealtime
Modified by 4NLINE UNLIMITED at 11:30 AM 2/4/2006
94</TD></TR></TABLE>My amp it self was rated at 1087RMS.... they come with a Check Sheet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics »</TD></TR><TR><TD CLASS="quote">wouldn't buy a prefab, fyi</TD></TR></TABLE>
Yea.... lol. I got a Custom Stereo West box made for the Specs and Power Handling for the 12W7
Neh, 600 for a 13in w7 is ebay price anyways. Box was just there and I couldn't pass it up. Looks good too, I'll probably end up building a diff box and using the black laminate and aluminum bars for it to look cool.
Modified by 4NLINE UNLIMITED at 11:30 AM 2/4/2006</TD></TR></TABLE> OIC, Only in Australia you say, well according to the specks it would make a good amp for the 12W7, a little extra wattage is a good thing, don't forget that its 1000W into 2 ohms at 14.4V the 12W7 is a 3 ohm sub, [Re 2.47 ohms] so it would be a good match up.
94
94
