what do i need to do to swap an f22b1 sohc vtec into a 91 accord 2 door coupe lx
what do i need to do to swap an f22b1 sohc vtec with a poa ecu into a 91 accord 2 door coupe lx i kinda need to know where to get the pinouts so i can wire in vtec
dude im doin the same swap and i have spent like a month tryin to fint out details
there is one guy that has done it in this forum his name was andrew from des
moies go into the member list and look for him i dont remember his screen name
but he says all the details bout the swap good luck man o i think u need to get a
jumper harness to obd 1 but here is the wiring
Vtec is A4 and Vtec pressure switch is D6. The black wire in the vtec pressure switch goes to ground
wadddu mean my car has grey plugs at the ecu so its obd1 already i think
what do you meen grey plugs at the ecu?where did you get the car because obd conversion harnesses are usauly grey the stock wiring harness is like multi colored like a homo rainbow
the f22b1 is out of a 95 so it will work im using my intake and the ex 94-97 accord header
if its got a POA ecu its obd1, OBD2 is 96+.
IIRC is just drops right in and you gotta swap pins a6 and a11 cuz the POA ecu has the o2 and egr swapped
WAT U MEAN SWAPPED ON THE ECU HARNESS OR WAT AND WAT IS IIRC
1994RedIntegra
May 30, 2012 03:17 PM
adams90crx@msn.com
Dec 17, 2010 12:47 PM
