help 95 civic cx swap d16z6 into it
Old Feb 1, 2006 | 05:55 PM
civic_eg's Avatar
Default help 95 civic cx swap d16z6 into it
it started but only problem is i'm still using cx o2 senser and i broke iat senser it started all up but it idles a funny and i don't have any check engine lights so whatz wrong?
Old Feb 1, 2006 | 06:04 PM
92hatchling's Avatar
Default Re: help 95 civic cx swap d16z6 into it (civic_eg)
how did you break the iat sensor? fix it and you should be ok
Old Feb 1, 2006 | 06:07 PM
civic_eg's Avatar
Default Re: help 95 civic cx swap d16z6 into it (92MiniMeHatch)
it melted when when i pluged it in wrong
Old Feb 1, 2006 | 06:08 PM
hw did you break the IAT sensor fix that and you should be ok
Old Feb 1, 2006 | 06:09 PM
well ok but yea fix it and it should be fine wheres it idle at
Old Feb 1, 2006 | 06:11 PM
civic_eg's Avatar
1000 then 1300 up and down
Old Feb 2, 2006 | 10:17 AM
also check intake mani gasket for leaks spray starter fluid around it if it rev higher fix the gasket
yaleforizzle
Aug 22, 2004 12:00 AM
neocrynym
15
Jul 30, 2004 09:11 PM
ef9wpb
Apr 4, 2004 09:09 PM
91lsvtecrx
Jan 19, 2004 06:18 PM
