JDM H22 vs USDM H22 - Differances?
hi all - just wondering exactly what differences there are between the two motors besides 10 hp i think . looking to buy a prelude with a jdm h22 in and would like to know more ! thanks. also i think the prelude is running the stock usdm ecu. any help is very much appreciated. car is a 98 base.
compression is different.
search.
you can find the specifications from f22/h23/h22 usdm/hdm.
very easy to come across.
https://honda-tech.com/zerothread?id=866663
search.
i remember vaguely now that u mentioned both are from japan. i didnt know about the adjustable tps and no cold start valve ! so no worries about having to switch an ecu ? thanks ! i tried searching but nothing was coming up -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftinflyboy »</TD></TR><TR><TD CLASS="quote">hi all - just wondering exactly what differences there are between the two motors besides 10 hp i think . looking to buy a prelude with a jdm h22 in and would like to know more ! thanks. also i think the prelude is running the stock usdm ecu. any help is very much appreciated. car is a 98 base.</TD></TR></TABLE>
i know some differences. For the JDM you have to use SEArch and for the USDM use seaRCH.
j/p
well...
USDM 190 hp / JDM 200 hp
the compression for USDM is 10:1 and JDM 10.6:1
injectors for USDM about 290 cc and JDM 320cc ...i think
and for all that to work OK the ecu has litle bit different programing
can't remember anything else...
now if its gonna be the jdm type-S (220 hp)
the compression is 11:1 (or some say 11.1:1 ...i don't know for sure)
little bigger injectors (i'm not sure about that, may be is the same with the JDM 200hp H22)
more angressive cams ...not much but there is a difference
single runner intake manifold (wich the othe h22's have dual runners with tb's to optain more tq on low rpms)
and for sure the ecu programing
and i also believe, as i have seen from pics, the stock header is a little diff too on the type-S
just some info from me
Modified by Buffalo at 6:48 PM 2/2/2006
j/p
well...
Heres a relavant question, Can I put a JDM obd1 head onto a USDM obd2 block?? Before all you posers start to say" sure no problem.." I asked this question about the oil pan and everyone who answered said "sure no problem,only diffrence is one is steel and the other is aluminum" Well this is not true the pan doesnt fit there are suble diffrences as to why not. So only answer if you know fo sho!!!
<u>Dont post bs if you dont know youre right, because youre not</u>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buffalo »</TD></TR><TR><TD CLASS="quote">injectors for USDM about 290 cc and JDM 320cc </TD></TR></TABLE>
obd1 h22a injectors are 345cc regardless (peak and hold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buffalo »</TD></TR><TR><TD CLASS="quote">the compression is 11:1 (or some say 11.1:1 ...i don't know for sure)
little bigger injectors (i'm not sure about that, may be is the same with the JDM 200hp H22)</TD></TR></TABLE>
its 11:1, and the injectors are the same as any other obd2 h22, 290cc saturated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buffalo »</TD></TR><TR><TD CLASS="quote">more angressive cams ...not much but there is a difference
single runner intake manifold (wich the othe h22's have dual runners with tb's to optain more tq on low rpms)</TD></TR></TABLE>
the cams are much more aggressive, and type-s h22as have dual runners, its the euro r that doesnt
The head swaps fine as far as I know I think I did one once I can't remember the exact years of the two heads though But I believe it's teh same in every way. The oil pans don't swap though like you said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote"><u>Dont post bs if you dont know youre right, because youre not</u>
i said "...i think
" so stop being a smart ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">yes sir. my sincerest apologies
this just in - posting your thoughts in place of facts is good</TD></TR></TABLE>
ahaha, jackass
oil pumps are different. Lower timing cover is different. Oil pan/baffles are different, different intermediate shafts....uh, cant think of anything else that hasnt been said.
ahaha, jackass
