D15B6 Pistons? w/JDM D15B head
Old Feb 1, 2006 | 12:02 PM
Ahks's Avatar
Default D15B6 Pistons? w/JDM D15B head
I just want to do this right... I may be getting my grubby paws on a JDM D15B VTEC head but i don't wanna be nub and just slap it on there.
I really should rebuild my bottom end or get a different block seeing as mine has 260k+ miles on it.
My question is what pistons should i use in my b6 block for a decent CR? p29/pm7 if they fit?
Or should I scrap my B6 and just get a different d-series block that can wind a bit higher? i'm broke so i'm working off a tight budget too
power on a budget...
Old Feb 1, 2006 | 01:25 PM
Ahks's Avatar
Default Re: D15B6 Pistons? w/JDM D15B head (Ahks)
i wish the d-series.org mod would approve my join i'd stop bugging you guys for d-series stuff
Old Feb 1, 2006 | 01:49 PM
beyondspexj's Avatar
well your trying to use ur hf pistons?? if so then its a waste. if you want to do a mini me ( basicly what the jdm d15b vtec motor is; i have one as well ) then grab a d16a6 or d16y7 block and grab some aftermarket pistons.
Old Feb 1, 2006 | 01:55 PM
gnar kill's Avatar
Default Re: (beyondspecs_jamar)
if b6 is the 8 valve I am almost sure those pistons will not work with a 16 valve head......also I have a d16a1 rods pistons and crank....i dunno if you can swap them in but I am pretty sure you can LMK if you need em
Old Feb 1, 2006 | 06:17 PM
Ahks's Avatar
Default Re: (gnar kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">if b6 is the 8 valve I am almost sure those pistons will not work with a 16 valve head......</TD></TR></TABLE>
b6 pistons have 2 valve reliefs per piston so it wont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">also I have a d16a1 rods pistons and crank....i dunno if you can swap them in but I am pretty sure you can LMK if you need em</TD></TR></TABLE>
i'm pretty sure that the d16 crank is almost totally incompatable with the d15 block
but how much for just the pistons
attica
Dec 21, 2010 06:11 AM
superturboprelude
May 12, 2007 01:47 PM
TYPErCRX
Jul 24, 2006 11:15 PM
no_one_
Mar 14, 2005 05:54 PM
