Having trouble re-setting "maintenance required" light
Old Feb 1, 2006 | 11:27 AM
vettman's Avatar
Default Having trouble re-setting "maintenance required" light
Local tire store did 30K maintenance, oil change, etc. Now the "maintenance required light" won't reset using procedure outlined in the owner's manual. Vehicle is a 2001 Accord LX withe 4 cylinder engine. Using the specified procedure, light will go out but then comes back on immediately. Any suggestions/recommendations, etc. would be appreciated.
Old Feb 1, 2006 | 11:43 AM
iam7head's Avatar
Default Re: Having trouble re-setting "maintenance required" light (vettman)
try harder, make sure the timing is exact.
Old Feb 1, 2006 | 03:39 PM
Ross 2.0's Avatar
In a Junkyard near you.
1. Push and hold the trip reset button
2. turn the ignition to on while holding the button still untill the light goes off.
Old Feb 13, 2006 | 02:40 PM
Chester Rumble's Avatar
Default Re: (MooGoCow3)
Will this work for an Integra too?
Old Feb 13, 2006 | 03:25 PM
RnEpmc's Avatar
why does the mantience required light come on?
Old Feb 13, 2006 | 03:33 PM
BLKFLSH's Avatar
Default Re: Having trouble re-setting "maintenance required" light (RnEpmc)
It is set to come on at a predetermined mileage interval. 6-7,000 miles (more or less). It is only a reminder, to remind you to do the required maintenance on your car.
Old Feb 13, 2006 | 04:27 PM
Default Re: Having trouble re-setting "maintenance required" light (BLKFLSH)
I found my answer as well... Search > me
Old Feb 14, 2006 | 08:21 AM
CB5F22A1's Avatar
I'm a Jackass
Default Re: Having trouble re-setting "maintenance required" light (Chester Rumble)
so how do you reset it on a 92 accord?????
Old Feb 14, 2006 | 06:35 PM
98accrd's Avatar
Default Re: Having trouble re-setting "maintenance required" light (CB5F22A1)
Push the recessed button in the gauge cluster with your key.
clewis3
Mar 22, 2010 05:16 AM
thefirstgen
Jan 27, 2010 05:12 AM
khoalizzle
Oct 5, 2008 04:06 PM
justpassin
Sep 15, 2006 12:59 PM
edger8cer
Jul 21, 2005 06:03 AM
