ECU not blinking, car won't start...
Old Feb 1, 2006 | 10:38 AM
trooper0641's Avatar
Default ECU not blinking, car won't start...
Fuel and spark is there...the ecu does not blink like it use to. It use to blink a code 6 when I put the car into the second "ON" position. But now my car won't turn over. Any ideas?
Old Feb 1, 2006 | 10:50 AM
civbeater90's Avatar
Default Re: ECU not blinking, car won't start... (trooper0641)
check your grounds and if you can use another good ecu.
Old Feb 1, 2006 | 11:31 AM
bryant's Avatar
Default Re: ECU not blinking, car won't start... (civbeater90)
Pop the valve cover. See if your timing belt is on.
Old Feb 1, 2006 | 11:44 AM
wickedEFguy's Avatar
Main relay may have gone out, does your CEL come on when you put the key to the "On" position and can you hear your fuel pump prime before starting your car?
Old Feb 1, 2006 | 10:22 PM
Default Re: ECU not blinking, car won't start... (wickedEFguy)
nvm guys it was soo gay...turned out to be a overlooked fuse...the small 10A altenator soldenoid crap of a fuse.
Zeratul
Engine Management and Tuning
Sep 28, 2016 03:31 PM
hotinteggy
Oct 22, 2007 04:44 PM
Lucky-13
Mar 23, 2007 09:33 PM
DC2 Mang
12
May 24, 2006 05:48 PM
illestrolla247
Apr 4, 2005 06:24 PM
