AIR CONDITIONING FOR CRX WITH B18C SWAP
My question is....
WHAT DO I NEED.
I have tried to find a list of parts to buy and cannot anywhere. I really have no idea on a/c units at all and dont know whats involved.
Anyone with that has installed a unit in a crx and knows what i need or can actually find a link please help me out. Im prepping for summer. Someone that has done a swap and also knows how it will fit or what problems ill run into with lack of room and non stock engine would also be helpful.
Thanks
Warren
WHAT DO I NEED.
Thanks
Warren
all you need is the standatd ac components for a crx and then buy a bracket from
http://www.hcpengineering.com/
im actually have a b18c crx with ac but i am removing it in the next couple days
Bump cause I need the same info . SO what mounts/ brackets are available ? Is it only the HCP & Hasport ? What if you switched to a 1/2 size eg radiator , where do you put the extra fan ?Also post some pix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexhuffer »</TD></TR><TR><TD CLASS="quote">Hey chaplin.....lets see some pics....NEED MORE INPUT PLEASE....</TD></TR></TABLE>
sorry dont have a digital camera plus i started removing the lines already. But I had a oem crx with a/c. Everything remained in the stock location. I swapped in a b18c. all i needed was the hcp bracket and everything bolted up perfect.
i used hasport motor mounts with the hcp ac bracket.
I will be selling the bracket soon and ac lines etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin »</TD></TR><TR><TD CLASS="quote">
So you used the CRX a/c tensioner and not the teg?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~Aj~ »</TD></TR><TR><TD CLASS="quote">
So you used the CRX a/c tensioner and not the teg?</TD></TR></TABLE>
yep crx 1
yep crx 1
zexhuffer
13
Jan 30, 2006 07:58 PM
Dainbramage
Apr 21, 2004 01:29 PM
