Jdm Type R Rev Limit!!!!!
Old Feb 1, 2006 | 07:06 AM
Blk93Sihatch's Avatar
Default Jdm Type R Rev Limit!!!!!
How High can you rev your stock Internal Jdm ITR with out hurting anything,
I mean with out bending any valves or hurting any rods.
Please Post
Old Feb 1, 2006 | 07:41 AM
digital sol's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (Blk93Sihatch)
8900 rpm
Old Feb 1, 2006 | 08:09 AM
BS 22's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (digital sol)
11000 RPM on stock internals...don't worry about that little red line
Old Feb 1, 2006 | 08:13 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Jdm Type R Rev Limit!!!!! (BS 22)
As far as it will let you!
Old Feb 1, 2006 | 09:03 AM
s2kdre's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (INTEGRA_boy)
u dont need to rev it past 8500 anyways, those cams drop off at 8100
Old Feb 1, 2006 | 09:14 AM
Lsos's Avatar
Everything in the engine is designed for fatigue. This means that you could probably rev it much higher than redline, but for nowhere near as long as if you stayed below redline (this is of course disregarding valve float...once that happens they are probably gone)
Old Feb 1, 2006 | 03:01 PM
Downey's Avatar
ive been told anything over 8600 you need valve springs and or retainers. im sure you could get away without them but theres not point in revving that high with stock cams.
Old Feb 1, 2006 | 04:09 PM
Default Re: Jdm Type R Rev Limit!!!!! (Downey)
come on I know people know more
Old Feb 1, 2006 | 04:12 PM
K20Death's Avatar
Who cares about how high it can rev...
Old Feb 1, 2006 | 04:13 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk93Sihatch &raquo;</TD></TR><TR><TD CLASS="quote">come on I know people know more</TD></TR></TABLE>
what the expletive more do you need to know??
Old Feb 1, 2006 | 09:09 PM
integtonx's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (JUN.R)
the red line is only when the engine starts feeling the extra stress.
Old Feb 1, 2006 | 10:06 PM
typeR#0427's Avatar
are you asking what the rev limiter is set at on a JDM ecu?
Old Feb 2, 2006 | 02:44 AM
B7AudiA4's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (hamB18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">are you asking what the rev limiter is set at on a JDM ecu? </TD></TR></TABLE>
pretty much...
the whole red part of the guage is the section you should shift at. So 8500-10,000 RPM is when you should shift at. (thats JDM for you)
Old Feb 2, 2006 | 04:00 AM
MiraiZ's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (walker111)
I do 13,000 daily
Old Feb 2, 2006 | 06:22 AM
totsie7944's Avatar
Default Re: Jdm Type R Rev Limit!!!!! (integtonx)
it really shouldn't matter how high you can rev your engine, safely or not.
All that matters is when you stop making power, thats when you should shift. And on a stock build you won't be making power high enough to worry about hurtin the motor. Be smart with it.
Old Feb 2, 2006 | 12:03 PM
THMotorsports's Avatar
The only reason to rev past that high is if your on a road course and coming into a turn where you want to go faster, but upshifting will loose you time since the next turn will come up very soon and you would have to downshift. That is the only time i found my 8500 rev limit on my JDM R a problem. Lucky me, the stock gauge cluster is off and 9k on mine is about 8400 in reality so on the road course, I will let it get up to 9k claimed if nessecary so I dont loose time.
Eddie
Old Feb 2, 2006 | 01:12 PM
IntegraType-R's Avatar
Default Re: (Truehondacom)
been revingmy itr motor to 9400 for about 2 years now no problem.. added a catch can for safety tho..
Stillo
Oct 6, 2006 01:51 PM
Baron55
Sep 18, 2006 09:38 PM
aznsmtboy
15
May 29, 2004 10:22 PM
TypeR 01 886
Jul 30, 2003 03:10 AM
