D16a6 Compression
Old Feb 1, 2006 | 06:53 AM
KansasKev's Avatar
Default D16a6 Compression
Is there is a rule of thumb:
I am doing a d16a6 rebuild and am wondering what a safe/reliable compression ratio is? I know stock is 9.1:1. This is for an everyday driver and NO future plans to boost.
I was thinking about keeping the stock pistions, using a Y8 head gasket, and milling the head.
I am not sure on the recommended amount to mill the head?
Any info is appreciated.
Thanks.
Modified by KansasKev at 8:17 AM 2/1/2006
Old Feb 1, 2006 | 07:15 AM
yz125rider21's Avatar
Default Re: D16a6 Compression (KansasKev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KansasKev &raquo;</TD></TR><TR><TD CLASS="quote">Is there is a rule of thumb:
I am doing a d16a6 rebuild and am wondering what a safe/reliable compression ratio is? I know stock is 9.1:1. This is for an everyday driver and to future plans to boost.
Thanks. </TD></TR></TABLE>
think a z6 head gasket would be better for boost if I am correct and I wouldnt mill head to much Just tell shop to clean it up...boost dont like high compression...milling head will start bumping it up
Old Feb 1, 2006 | 07:16 AM
KansasKev's Avatar
Default Re: D16a6 Compression (yz125rider21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">
think a z6 head gasket would be better for boost if I am correct and I wouldnt mill head to much Just tell shop to clean it up...boost dont like high compression...milling head will start bumping it up</TD></TR></TABLE>
Opps I mean NO future plans to boost.
Old Feb 1, 2006 | 08:51 AM
bagpipe goatee's Avatar
that looks good. the only problem i know of with milling the head is if you to too far, the cam timing gets off adjustment a little unless you get an adjustible cam gear and install it a little off in the direction you want.
Old Feb 1, 2006 | 03:07 PM
KansasKev's Avatar
Default Re: (bagpipe goatee)
Bump...
Old Feb 1, 2006 | 04:03 PM
UltimX's Avatar
Default Re: (KansasKev)
mil the head .030 thou.... and compression is 9.5:1
Old Feb 1, 2006 | 07:36 PM
KansasKev's Avatar
Default Re: (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">mil the head .030 thou.... and compression is 9.5:1 </TD></TR></TABLE>
I came up with 9.7:1 using the http://www.zealautowerks.com/dseries.html
So the mill of .03 and a Y8 headgasket = 9.95:1
Xemu
Apr 24, 2007 04:22 PM
mike93eh
Jul 19, 2005 08:04 PM
ELSpool
Dec 3, 2003 12:13 PM
zexdrex
Oct 16, 2002 08:45 PM
