Removing p/s, what size fittings? (pics)
Old Feb 1, 2006 | 01:49 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Removing p/s, what size fittings? (pics)
Does anyone know what size these blue fittings are?
Once I get them I can start on taking it out, but I don't know what size.
Also, the line coming off the top of the p/s pump,
that looks like it's going into the firewall, anyone know what you do with that one?
It's not part of the ones you loop, so I wasn't quite sure of what you do with it.
Old Feb 1, 2006 | 05:19 PM
Hype-R Stalker
Default Re: Removing p/s, what size fittings? (FlatBlackTeg)
bump
Old Feb 1, 2006 | 06:26 PM
IN VTEC's Avatar
Those look like -6AN flare fittings. You can use whatever AN size hose-ends and line to loop them or remove them to use barbed-to-NPT adapter fittings.. The rack looks like it's been tapped for 3/8" NPT to use the pipe-to-AN adapters.
As for the PS pump high-pressure feed line, just remove it along with the pump.
Old Feb 1, 2006 | 06:58 PM
Hype-R Stalker
Default Re: Removing p/s, what size fittings? (IN VTEC)
awesome, thanks.
I wanted to get that figured out before the weekend,
Thought it'd be a good idea while my engine is out to do the p/s then.
Old Feb 1, 2006 | 08:17 PM
Erik95LS's Avatar
Looks like -6AN to me as well.
Nick97hatch
Feb 15, 2009 04:19 PM
92redhatch
Jul 4, 2008 03:05 PM
b00stedbyFastrax
Apr 20, 2006 03:54 AM
mark45840
Mar 24, 2005 07:36 PM
Snail Tuning
Feb 1, 2003 08:44 PM
