Need advice on Wiring harness
Old Mar 24, 2002 | 04:09 PM
JohnnyEF's Avatar
Default Need help on engine harness dx to si
Someone wants to buy my 88 crx si wiring harness from my engine to ecu plugs. I believe he has a 88 crx dx. I know from the ecu plugs that there are some wires go under the dash poss to the fuse box. Do the ecu plug wires go anywhere else than to the fuse box? Does it go to the cluster? What is the easiest way to take the harness out? Do I need to take out the carpet and dash? I was thinking if I could take out the wires from the plugs that not go into the engine bay. Can he put the missing harness wires from my ecu plugs with his wires from under his dash or wherever they may come from inside the car. Would this be plug and play for him by looking at his ecu plugs? Are all dx wires coming from under the dash the same location on plugs as mine? If anyone can help I would appreciate it.
BTW his harness is chopped up thats why he wants a si harness. I know that using the DX harness would be easier.
[Modified by JohnnyEF, 4:34 PM 3/25/2002]
Old Mar 25, 2002 | 07:35 AM
JohnnyEF's Avatar
Default Re: Need help on engine harness dx to si (JohnnyEF)
TTT
Old Mar 25, 2002 | 07:43 AM
maximedx's Avatar
yes its pretty easy if you remove your capet and your dash.But you can take off the wiring harness if you can not take off the dash just remove the cluster and cluster console because you have two or three plugs behind this.One of the plugs is yellow.
Old Mar 25, 2002 | 10:01 AM
turbo_ef9's Avatar
Default Re: Need help on engine harness dx to si (maximedx)
it's pretty easy.. no need to take out the dash.. just wrap up the carpet, unplug it all and put the new harness in.. i did this with mine.. easy.. that harness is like 6 ft long.. hehe.. have fun...
RobEJ
Engine Management and Tuning
Aug 1, 2016 01:35 PM
nocsyn
Aug 10, 2009 05:34 PM
zcmotor
Jun 3, 2008 12:02 PM
aug
Jan 8, 2008 09:05 PM
HondaInteg95
Aug 28, 2005 12:28 AM
