chech engine light
Old Jan 31, 2006 | 07:25 PM
pec pec's Avatar
Default chech engine light
ok so when i first start my car the check engline light isnt on but after a few moments or drving it around it turns on for what reason can this be n e help with b helpful thank u very much
Old Jan 31, 2006 | 07:33 PM
vw eater's Avatar
Default Re: chech engine light (ef9 562)
search....maybe under check engine light..
Old Jan 31, 2006 | 07:46 PM
naptownrex's Avatar
Default Re: chech engine light (vw eater)
A "check engine light" usually denotes a sensor problem. Check the ECU (which is under the carpet where the passenger's feet would go if he or she were sitting in the passenger seat) and determine if the red LED light is blinking (there may be a metal cover on top of the ECU, in which case you may have to pull it off to see the light, but I think theres a hole drilled in it so that you dont need to remove it.) If the ECU's LED light is not blinking when your check engine light comes on, then it may be more difficult to diagnose.
Devious951
May 29, 2007 04:43 PM
rccnh
Mar 12, 2007 01:29 PM
jb0705
Acura TL, RL & ZDX
Nov 5, 2006 05:15 PM
jdium
Mar 4, 2006 10:13 PM
ex_crxer
Apr 6, 2002 07:54 AM
