H2B adapter plate For NHRA??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopher M »</TD></TR><TR><TD CLASS="quote">Cough Bisi</TD></TR></TABLE>
LOL I know.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 »</TD></TR><TR><TD CLASS="quote">but its not upgrading your actually going smaller (downgrading) so i dont see why it would be a problem in my opion </TD></TR></TABLE>
right, i had the same argument... but just says oem to block.
well as far as hot rod is concerned....they're using xtrac and g-force trannies and the the gms are running the hydramtics so i wouldnt see the harm of using a bseries trans on a h motor....
would the h2b plate work on an h motor with an xtrac?
From what they ( NHRA ) told me is that the trans must match the block for the sportman class - turbo or almotor. So H22 must have H22 trans im sure you could get away with Accord or H23 trans because it still bolts directly to the H block.
If you are in the Pro class you can take a 150 lbs ( i think ) penalty for what ever trans you want to run - xtrac etc etc. Or in bisi's case the sohc on the f block -
This is why you wont see many SFWD/NHRA cobalts - they have a GM trans but it is out of a van and NHRA said NO NO NO
Be Happy the H Motors can't run the B Trans...because then the Cobalts could run a Grans Prix Trans and wreck everyone badly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Be Happy the H Motors can't run the B Trans...because then the Cobalts could run a Grans Prix Trans and wreck everyone badly.</TD></TR></TABLE>
My vote was for the rule to allow it
- Racin is racin
I talked with NHRA about it all winter and they would not even think about it, they stuck to their guns.
- Racin is racin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">How would they know you switched trannys?</TD></TR></TABLE>
Well in the Cobalt you would heat the other guys cry and see the adaptor plate -
In the hondas you wouldnt know the difference between say b16/b18 or h22/h23/F but in the case of this topic you would see the H motor then adaptor then B trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason@Rage »</TD></TR><TR><TD CLASS="quote">
but in the case of this topic you would see the H motor then adaptor then B trans</TD></TR></TABLE>
yep, it's pretty obvious with the plate and different starter location.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">Just spoke with NHRA, Its a no go on the trans for me.
He did say that they are looking to revise the rules without pissing the GM guys off, but it may not happen until mid-season.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludes »</TD></TR><TR><TD CLASS="quote">not in sfwd, i emailed and got the response that only transmissions that are oem to the block are allowed.</TD></TR></TABLE>
does that mean someone with a GSR and type-r tranny wouldnt qualify? what exactly does nhra's rulebook say. transmission that are oem to a block is the case, then what about all the people who have been runnin motors with different trannies all these years. its a very contradictory rule on nhra's part if u ask me.
The rules means B Series Motor = B Series Tranny. GSR and Type-R are Both
B Series Motors = OK!
FYI. I'm not posting to debate the rule, I was just answering this gent question.
Race On!
D1320Don
Javier
Race On!
D1320Don
Javier
In my thought process, if they allow the H2B trans swap, they would have to allow the cobalts to run the 4t-65 trans, which I don't see happening.
