97 accord ex engine into a 94 honda accord ex whats needed?
Old Jan 31, 2006 | 02:01 PM
94_civicEx's Avatar
Default 97 accord ex engine into a 94 honda accord ex whats needed?
I'm am getting ready to put a 97 accord ex engine into my 94 honda accord ex. Will it be a direct drop into my car. What other things will be needed?
Old Jan 31, 2006 | 02:10 PM
P_Adams's Avatar
Default Re: 97 accord ex engine into a 94 honda accord ex whats needed? (94_civicEx)
The only way it would be any easier would be if it had zippers.
While you're putting the '97 in, give some thought to putting a new timing belt in it while you've got it out. That way you don't have to worry about it later.
P
Old Jan 31, 2006 | 02:20 PM
cdsquad.net's Avatar
Default Re: 97 accord ex engine into a 94 honda accord ex whats needed? (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">The only way it would be any easier would be if it had zippers.</TD></TR></TABLE>
You need to recommend this to Corporate
Old Feb 2, 2006 | 08:51 AM
94_civicEx's Avatar
Default Re: 97 accord ex engine into a 94 honda accord ex whats needed? (cdsquad.net)
Old Feb 3, 2006 | 06:37 PM
94_civicEx's Avatar
Old Feb 3, 2006 | 11:12 PM
YeuEmMaiMai's Avatar
just make sure that you use all of your engin's sensors since 97 are obd2 and 94 are ond1 cars. otherwise drop it right in. while you got it out, i would in addition to the timing belt, due valve adjustment and replace the gasket set while you are at it. Also isnt a bad time to pull the oil pan and inspect the bottom end.
Old Feb 7, 2006 | 08:52 AM
94_civicEx's Avatar
Default Re: 97 accord ex engine into a 94 honda accord ex whats needed? (YeuEmMaiMai)
thanks
Old Feb 15, 2006 | 08:06 PM
94_civicEx's Avatar
i swaped the motor in today but when i went to start it up it just cranked and checked but there was no spark so i check the harness again but no spark and tested the distrutor on my friends car and there was spark. i used my old harness and switch some stuff that the old harness needed over
brianratliff
Dec 8, 2015 02:07 PM
Matthew39
Apr 19, 2015 10:12 AM
boiwitwhitehond
Oct 27, 2003 11:29 AM
