Emissions Help!
Old Jan 31, 2006 | 01:29 PM
tony's Avatar
Default Emissions Help!
update: All it needed to pass was a new air filter
Went for test today and failed.....
Now why would I fail when they do a test while simulated driving but not on idle?
Also what part could be the leading cause.
Thanks
Stock D16y7 engine with just intake
everything else stock
Modified by tony at 5:05 PM 2/2/2006
Old Jan 31, 2006 | 03:16 PM
tony's Avatar
Default Re: Emissions Help! (tony)
Should i change my intake back to stock?
Old Jan 31, 2006 | 03:34 PM
saywhat's Avatar
maybe a tired cat or O2 sensor, and when was the last time you changed your oil.
Old Jan 31, 2006 | 03:39 PM
tony's Avatar
Default Re: Emissions Help! (saywhat)
changed the oil. spark plug. and wires the day before i went.
Old Jan 31, 2006 | 06:09 PM
tony's Avatar
bump
Old Jan 31, 2006 | 06:11 PM
97spooncivic's Avatar
how many miles on the motor and cat?
Old Jan 31, 2006 | 06:20 PM
tony's Avatar
Default Re: Emissions Help! (97spooncivic)
140,000 miles on the motor and i think around 50,000 on the cat
Old Jan 31, 2006 | 08:15 PM
eXcelonTypeR's Avatar
Try a new cat. I burnt my cat out like 3 months after having it. Too much fun with the b16 lol
Old Jan 31, 2006 | 08:33 PM
JeffBro's Avatar
Default Re: Emissions Help! (eXcelonTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Try a new cat. I burnt my cat out like 3 months after having it. Too much fun with the b16 lol</TD></TR></TABLE>
Prob too much fuel in addition to fun..
Old Jan 31, 2006 | 10:35 PM
built562's Avatar
Default Re: Emissions Help! (JeffBro)
we need to see the numbers of the test, then we can see what might be the problem. scan or just post up all the numbers of the test
*edit* the pic was not showing up for me, but its up now
Old Feb 1, 2006 | 12:25 AM
drewbie*'s Avatar
Default Re: Emissions Help! (built562)
SEAFOAM.
Old Feb 1, 2006 | 12:41 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: Emissions Help! (Drew95eg)
Try seafoaming it, oil change, and have them check your 02 sensor. If none of them, have them check your cat. Your running rich, that means too much unburnt fuel. What kind of plugs did you put in, did u put em in wrong? are you running OEM wires? is your dizzy ok?
Old Feb 2, 2006 | 01:03 PM
tony's Avatar
ThaLost0ne
Mar 5, 2008 02:28 PM
jchrm80
Jun 8, 2007 07:35 AM
k7q
14
Mar 6, 2006 03:50 PM
88 rex
Aug 16, 2003 06:15 AM
Splangtastic
Jun 19, 2003 01:30 PM
