car shakes!!!
check ur axles...usually jacked up axles would make ur car shake on acceleration...but give it a shot...i had warped rotors and put some new drilled and slotted rotors on and the shaking went away...not to mention great new braking power
yes steering wheel shakes, but the whole car does too!!.....well when im excelerating it doesnt shake bad but when i left off even to shift it shakes, if im going like 80+ and let off nothin only between like 45-70, i checked tire pressure brakes and rotors seem fine a little wear nothin to bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devo94ac »</TD></TR><TR><TD CLASS="quote">its kinda funny i just replaced my brakes and rotors</TD></TR></TABLE>
check your cv boots...if there ripped..***** gonna get messd up due to the grese leaking out...i remember in my last car a boot was ripped and my whole car started shaking uncontrolably..especially while making mild bends on the parkway...at high speeds only...just like you said..i went thru everything..checked brakes...wheel lugs...tires..everything possible...ended up being the half-shaft.
are your rotors and pads set up correctly....anytime someone else replaces something...i make sure to go back and check it over personally...i do not trust anybody with my vehicle...if you know what i mean.
..::91TEG-G2::..
Aug 12, 2003 03:25 PM
