wat is the name of this part?
Old Jan 31, 2006 | 10:35 AM
EFresh's Avatar
Default wat is the name of this part?
its not a good picture but its the best 1 could find, i found these parts laying the around the garage but i cant find the name of these parts. its located next to the intake manifold. Number 1 is black with anotehr circle object from the top that connects with number 2. can someone inform me with the common name of this part? thanks.
Old Jan 31, 2006 | 10:46 AM
jlicrx's Avatar
Default Re: wat is the name of this part? (fresh guy)
that is part of the Evaporative Emissions Control System - #1 is the charcoal canister and #2 is the Purge Cut-off Solenoid Valve - just to the left of the Purge cut-off is the MAP sensor
Old Jan 31, 2006 | 11:06 AM
VtecSyndrome's Avatar
Default Re: wat is the name of this part? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">that is part of the Evaporative Emissions Control System - #1 is the charcoal canister and #2 is the Purge Cut-off Solenoid Valve - just to the left of the Purge cut-off is the MAP sensor</TD></TR></TABLE>
Old Jan 31, 2006 | 11:07 AM
EFresh's Avatar
Default Re: wat is the name of this part? (VtecSyndrome)
thanks a lot
Old Jan 31, 2006 | 11:10 AM
AJxr's Avatar
and for the people who dont have emissions can the car run fine without the purge cutoff and the charcoal canister? to remove would you just bypass them?
Old Jan 31, 2006 | 12:42 PM
Default Re: wat is the name of this part? (AJxr)
Yea, just by-pass or plug the ports not needed on the Manifold. all you really need is vaccum on the FPR and map sensor
Old Jan 31, 2006 | 02:29 PM
YumVTEC's Avatar
fresh guy, i'll buy that whole assembly of sensors and vacuum tubes you show in your picture on the firewall if you have them laying around not doing anything.
Old Jan 31, 2006 | 02:43 PM
jlicrx's Avatar
Default Re: wat is the name of this part? (YumVTEC)
don't plug the vent line that comes from the fuel tank - everything else can go, unless you need to pass a visual emissions check
Old Jan 31, 2006 | 02:55 PM
DJM AutoWorks's Avatar
who really cares about emissions lol
Old Jan 31, 2006 | 02:58 PM
yz125rider21's Avatar
Us that live in CALI...lol
EFresh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">fresh guy, i'll buy that whole assembly of sensors and vacuum tubes you show in your picture on the firewall if you have them laying around not doing anything.</TD></TR></TABLE>
pmed
Dasfinc
Mar 5, 2008 06:56 PM
B18OnTop
Feb 19, 2007 11:59 PM
kyden
Sep 30, 2004 08:38 PM
DBallz
May 23, 2003 10:27 AM
