crome tuning p28 ecu question?
Old Jan 31, 2006 | 10:20 AM
spoon23_JDizM AkA SpOoN20's Avatar
Default crome tuning p28 ecu question?
ok heres the deal ordered this ecu for a prelude swap with nothing on it but lucas racing 440 injectors... if this is what its set-up for, how long can I run like this until I have to be tuned?
Also will vafc help in this situation? Need to know if this is enough to get the car drivable to drive 2 hrs to dyno?
Modified by spoon23_JDizM AkA SpOoN20 at 5:29 PM 2/1/2006
Old Jan 31, 2006 | 10:24 AM
Hybrid96EK's Avatar
Default Re: crome tuning p28 ecu question? (spoon23_JDizM AkA SpOoN20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon23_JDizM AkA SpOoN20 &raquo;</TD></TR><TR><TD CLASS="quote">ok heres the deal ordered this ecu for a prelude swap with nothing on it but lucas racing 440 injectors... if this is what its set-up for, how long can I run like this until I have to be tuned? </TD></TR></TABLE>
I'm not following what you are asking. Are you asking if you have a chip made for 440 injectors and did nothing else how long will it last? Thats something no one here can answer for you. Thats going to depend a lot on how far off the base map is. You shouldn't be messing with it at all until its on a wideband unless you have money to replace things when you blow them up.
Old Feb 1, 2006 | 07:07 AM
Default Re: crome tuning p28 ecu question? (Hybrid93Eg)
i mean even if i gave mtber my specs shouldn't that be ok?
Old Feb 1, 2006 | 08:12 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon23_JDizM AkA SpOoN20 &raquo;</TD></TR><TR><TD CLASS="quote">i mean even if i gave mtber my specs shouldn't that be ok?</TD></TR></TABLE>
I don't know who Mtber is, and you can't just give someone your specs and have a chip thats going to be spot on. someone can guess and make you a basemap, but that thing STILL needs to be on a wideband. Period.
Modified by Hybrid93Eg at 1:21 PM 2/1/2006
Old Feb 1, 2006 | 11:49 AM
rdtech's Avatar
Just have some one creat a basemap for you. A basemap is pretty much rich and the ignition is retarded sometimes. Start with a basemap and them tune using the basemap. You cant tune a car without having a basemap to start off with.
Old Feb 1, 2006 | 03:54 PM
Default Re: crome tuning p28 ecu question? (rdtech)
where can I purchase a basemap?
Old Feb 1, 2006 | 07:17 PM
hump
Old Feb 2, 2006 | 06:46 AM
Old Feb 2, 2006 | 11:36 AM
2k.civic.si's Avatar
no...all he does is give you a base map...good enough to drive lightly to the local tuner...your an idiot if you try to drive on a base map...if anyone tells you a "chiped" ecu will work for your setup he/she is full of ****
if someone tells you the bin was from a tuned car that is similar to yours and will be fine...run...run as fast as you can....he/she is also an idiot
also i wouldnt drive my untuned car for 2 hours straight...if its to lean or rich you will destroy your motor
Old Feb 2, 2006 | 07:14 PM
GOT14U's Avatar
Default Re: crome tuning p28 ecu question? (2k.civic.si)
TRUE DAT
Old Feb 2, 2006 | 07:39 PM
Default Re: crome tuning p28 ecu question? (GOT14U)
will a chipped p28 and rc 310 be ok then?
Old Feb 3, 2006 | 02:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon23_JDizM AkA SpOoN20 &raquo;</TD></TR><TR><TD CLASS="quote">will a chipped p28 and rc 310 be ok then?</TD></TR></TABLE>
no
Crazyycivic98
Engine Management and Tuning
Apr 20, 2015 08:44 AM
MurtazaDSM
Aug 8, 2009 08:23 AM
sp3nce
Dec 21, 2007 01:15 PM
SkoundrelUSA
Aug 17, 2006 10:08 PM
ludelvr
Dec 30, 2003 09:27 AM
