Vtec want engage on H22 in civic
Old Jan 31, 2006 | 09:36 AM
spoonzdelsol's Avatar
Default Vtec want engage on H22 in civic with H22 injectors
Okay this is got me stump so here I go. I have a 94 vx civic with a JDM h22 swap okay the ecu is a p13 chipped with JUN . The car came with B series injectors in the motor and I changed them out and put the h22 injectors in it. Now the car want hit Vtec it runs fine until it hits 5000 and then it boggs. I have resistor box wired up . Changed out MAP sensor . Only thing I can think of is the ecu I dont know I have tried everything so any help will be nice. Thanks
Old Jan 31, 2006 | 09:52 AM
DC4_MADMAN's Avatar
Default Re: Vtec want engage on H22 in civic with H22 injectors (spoonzdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonzdelsol &raquo;</TD></TR><TR><TD CLASS="quote">Okay this is got me stump so here I go. I have a 94 vx civic with a JDM h22 swap okay the ecu is a p13 chipped with JUN . The car came with B series injectors in the motor and I changed them out and put the h22 injectors in it. Now the car want hit Vtec it runs fine until it hits 5000 and then it boggs. I have resistor box wired up . Changed out MAP sensor . Only thing I can think of is the ecu I dont know I have tried everything so any help will be nice. Thanks </TD></TR></TABLE>
Any CELs? Have you tried resseting the ECU? Sounds like the ECU went into Limp Mode.
Old Jan 31, 2006 | 10:06 AM
No CEL car runs really good with the h22 injectors just when I go to hit Vtec it Boggs .
But with the B series Injectors it ideals bad but hits Vtec everytime .
Old Jan 31, 2006 | 10:20 AM
DC4_MADMAN's Avatar
Default Re: (spoonzdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonzdelsol &raquo;</TD></TR><TR><TD CLASS="quote">No CEL car runs really good with the h22 injectors just when I go to hit Vtec it Boggs .
But with the B series Injectors it ideals bad but hits Vtec everytime .</TD></TR></TABLE>
So you bought this car with the swap, it had a Jun chipped P13 and B16 injectors? Dont know much about ECU chipping, but maybe the chip requires the B16 injectors. See if you cant borrow a stock ECU and try the H injectors again. Also check the engine timing maybe its off too much and releasing to much fuel from the H injectors causing the bog.
Good luck.
Old Jan 31, 2006 | 10:23 AM
Thanks I think the ECU has something to do with it but I am having no luck in finding a H22 ecu . I have already check the timing its fine Thanks for the help
Old Jan 31, 2006 | 10:30 AM
aquabob89's Avatar
* B A N N E D *
Yea i would say try messing with ignition timing to match the fuel
Old Jan 31, 2006 | 11:55 AM
Specail Ed's Avatar
The impedence on B series and H series injectors are different, that's most likely the problem. If the ECU was chipped for the B series, high impedence injectors, it is going to run differently if you hook the H series injectors up along with the resistor box. That's the reason it's bogging when VTEC engages.
Old Jan 31, 2006 | 11:58 AM
IHateJDM's Avatar
Default Re: Vtec want engage on H22 in civic with H22 injectors (Specail Ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Specail Ed &raquo;</TD></TR><TR><TD CLASS="quote">The impedence on B series and H series injectors are different, that's most likely the problem. If the ECU was chipped for the B series, high impedence injectors, it is going to run differently if you hook the H series injectors up along with the resistor box. That's the reason it's bogging when VTEC engages.</TD></TR></TABLE>
Since its a JUN chip, i doubt its chipped for b series injectors, but I agree that the resistor box is the problem (if you don't have one already).
Old Jan 31, 2006 | 12:18 PM
jdmpremonition's Avatar
is ur speedometer working? did you correctly connect a ground to your vtec?
Old Jan 31, 2006 | 12:41 PM
everything is hooked up right No CEL or anything like that Car hits Vtec fine with b series injectors . It runs better with the H22 injectors but when you go over 5000 it boggs really bad I think it has something to do with the ECU but I dont know anything about Chipped ECU's
on-site ej1
Dec 15, 2008 08:08 AM
PremiumPrelude
Mar 12, 2008 01:25 PM
AFireInside904
Oct 31, 2006 02:22 PM
JDM_Risa
Feb 2, 2005 01:52 AM
h22acrd
Jul 17, 2004 03:03 PM
