ecu wont reset
Old Jan 31, 2006 | 09:33 AM
aquabob89's Avatar
* B A N N E D *
Default ecu wont reset
to try and get my ecu to restart ive pulled the 7.5 fuse for 10secs ive disconnected hte battery and everything but everytime it starts right up wiht a check engine light already on.
Old Jan 31, 2006 | 09:37 AM
philosofy1's Avatar
Default Re: ecu wont reset (aquabob89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquabob89 &raquo;</TD></TR><TR><TD CLASS="quote">to try and get my ecu to restart ive pulled the 7.5 fuse for 10secs ive disconnected hte battery and everything but everytime it starts right up wiht a check engine light already on.</TD></TR></TABLE>
back again, when you disconnect your battery, leave it disconnected for about 5 min.
what ecu are you running?
OBD(0), OBD(1), OBD(2)?
Old Jan 31, 2006 | 09:38 AM
Jammersplace's Avatar
Default Re: ecu wont reset (philosofy1)
if obd2b i pull the center plug and plug it back in and it resets it takes about 2 seconds or so
hillbilly's Avatar
What ecu do you have? if it is an obd2 you need the comp to reset it. If not I have absoultly no idea what it could be though...
Old Jan 31, 2006 | 09:50 AM
Everyones Hero's Avatar
Default Re: ecu wont reset (hillbilly)
Have you fixed the problem already? I did something stupid when I had chipped my ECU and it would throw a code the instant I started my car, even after resetting the ECU.
Old Jan 31, 2006 | 10:07 AM
aquabob89's Avatar
* B A N N E D *
Default Re: ecu wont reset (Everyones Hero)
i have a obd1 p28 ecu
Old Jan 31, 2006 | 10:08 AM
aquabob89's Avatar
* B A N N E D *
ive also blown ecu fuse before
after that my wiring harness burnt out
after all that it turned out i had a bad battery
Old Jan 31, 2006 | 10:14 AM
So, is it fixed?
Old Jan 31, 2006 | 10:18 AM
aquabob89's Avatar
* B A N N E D *
no it wont reset i was just saying that its had problems before im going to try the battery for 5 mins thing
Old Jan 31, 2006 | 03:08 PM
all_conference's Avatar
what codes do you get for your CEL? I get codes 41 and 48, after replacing the O2 sensor, i still get CEL. Tried resetting ECU, and still get CEL.....
crxsi814
Jan 18, 2011 06:25 PM
Fatty_1775
Aug 5, 2003 05:37 AM
CleanLIttleLude
Jun 13, 2003 12:09 PM
joblow
Feb 12, 2003 07:17 PM
