K&N Oil Filter
Old Mar 24, 2002 | 01:05 PM
5-SpeedFreak's Avatar
New User
Default K&N Oil Filter
I couldn't find a Mobil 1 oil filter for my last oil change, but I came across a K&N oil filter... It's on the car now.
I know that their air filters (at the end of my AEM CAI) are the best out there...
Anyone hear anything about their oil filters?
Old Mar 24, 2002 | 02:24 PM
non-VTEC's Avatar
Default Re: K&N Oil Filter (5-SpeedFreak)
i hear they are very good oil filters........
Old Mar 24, 2002 | 02:55 PM
GSRaCeRbOI's Avatar
I've always wondered how good their oil fiilters were too and was tempted to try it.. since my local Kragen doesnt seem to carry Mobil 1 anymore.. but I havent heard anything about them.. nothing good and nothing bad.. so i've been hesitant... I usually get Mobil 1, Bosch or STP (at autozone), Purolator Pure One (pepboys), or if the dealer sends those mailers w/ coupons on oil filters then i'll get an OEM haha..
any1 out there use the K&N oil filters?
Old Mar 24, 2002 | 03:24 PM
Bror Jace's Avatar
Default Re: K&N Oil Filter (GSRaCeRbOI)
The K&N's strong point is ability to flow LOTS of oil.
I talked to someone who had a Ford Contour SVT and they would race their cars. The problem was that at high RPMs, the 3gpm flow limit (gallons per minute) of the factory Motorcraft oil filter was inadequate to lubricate the engine and their owner's were not happy with the result.
Really high-efficiency filters (ones that try to grab every particle down to 5-10 microns) like the Mobil 1 and Purolator oil filters tend to be a bit restrictive. The K&N is built for racing (high-RPMs) but they probably won't grab a lot of the smaller particles ... but engineers are unsure if this matters. Those littlest particles probably don't do much, if any, damage to the motor's bearings and valvetrain surfaces.
In other words, the K&N is prettyy good.
--- Bror Jace
[Modified by Bror Jace, 12:27 AM 3/25/2002]
Old Mar 25, 2002 | 02:51 AM
New User
Default Re: K&N Oil Filter (Bror Jace)
The K&N Performance GoldŽ Oil Filter has been constructed from the ground up to satisfy the high performance needs of race car owners and drivers, as well as the average vehicle owner who wants the very best oil filter available. The oil filter's efficiency rating meets or exceeds the requirements of high performance automotive engine builders.
The heavy duty construction provides over 550 PSI hydrostatic burst, and helps reduce the risk of rock and stone damage.
The real quality isn't just on the outside... the inner filter element traps contaminant as small as 10 to 20 microns in size.
Using metal top end caps instead of paper to ensure that no unfiltered oil can get back into the system. The solid construction allows for oil flow rates between 12-16 gpm (depending on filter size), and is unaffected by racing fuels.
All K&N Performance GoldŽ Oil Filters are manufactured to exacting engineering standards. They are covered by a limited warranty to be free from defects in materials and workmanship when installed and replaced using engine and equipment manufacturers recommended service interval.
HTH
[Modified by 5-SpeedFreak, 3:55 AM 3/25/2002]
holmesnmanny
Dec 10, 2009 03:14 AM
happynoodleboy
Feb 20, 2008 06:34 PM
skunk2finatic
Oct 28, 2004 10:05 PM
Elfstone
Sep 20, 2004 04:12 AM
sslude
Feb 6, 2003 09:47 PM
