Did Distributor King send me the wrong Dizzy?
Old Jan 30, 2006 | 10:29 PM
.Manny.'s Avatar
Touching My Member
Default Did Distributor King send me the wrong Dizzy?
Hey guys this is the deal. I recently swapped in a Dohc ZC into my 90 hatch Si to replace the blown ZC that had been put in by the previous owner.
He did not repin the connector but rather hardwired them directly to eachother and it seemed to work until the dizzy started to go bad. So i took out the old one and noticed that this dizzy had two white wires and some peach ones too when i removed it.
Well i ordered a 88-89 integra dizzy from DK and this one has some blue wires and a green/yellow wire in place of a white wire that the old dizzy had. The dizzy is labeled TD-03.
Is this the right dizzy?? Car wont start, i even followed the wiring diagram i got off of thezcr.com and h-t.
Could jumpingthe battery fry an ecu?? I had to jump start my car a while back because the battery died.
Old Jan 31, 2006 | 03:46 AM
VegaS10's Avatar
I ordered the same dizzy from them last week and it has'nt arrived yet. Since the wiring colors on the DK one are different, you're gonna have to rely on pin placement on the dizzy. Since the previous owner cut the engine harness of, it's gonna require more work.
Old Jan 31, 2006 | 10:35 AM
.Manny.'s Avatar
Touching My Member
Default Re: (VegaS10)
bump for more reply's, i really need this car to run, i am going to school full time and i need a ride.
Thanks vega, i was shiting rocks.
Anyone else?
Old Jan 31, 2006 | 10:40 AM
CRX Toad's Avatar
Default Re: Did Distributor King send me the wrong Dizzy? (90_EF_Si)
Did you call them to confirm with them? That should be step one.
Old Jan 31, 2006 | 10:45 AM
.Manny.'s Avatar
Touching My Member
lol, im such a tool, going to do that right now, thanks.
Lets just presume it is the right one, how can i wire it up, there are no plugs at all thanks to the dude who had it before me. Please help me!!
Old Jan 31, 2006 | 10:48 AM
splitime's Avatar
Default Re: (90_EF_Si)
I'd suggest junkyard and hack a set of plugs off that work for the dizzy.... then get a Helms and use the wiring guide to repin the plugs into your harness.
Or just get a new engine bay harness.
Old Jan 31, 2006 | 11:05 AM
VtecSyndrome's Avatar
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest junkyard and hack a set of plugs off that work for the dizzy.... then get a Helms and use the wiring guide to repin the plugs into your harness.
Or just get a new engine bay harness.</TD></TR></TABLE>
Old Jan 31, 2006 | 11:09 AM
.Manny.'s Avatar
Touching My Member
do i need the helms for an integra?? will it all be there? Any one had this prob before?
thanks guys.
hey vtecsyndrome, hows yur buddy doing on posts? The guy dat kant sppelll 4 chit.
Old Jan 31, 2006 | 11:32 AM
.Manny.'s Avatar
Touching My Member
just got an email from the guy and he said its the same, kool.
So the integra helms would have everything i need??
Old Jan 31, 2006 | 12:07 PM
.Manny.'s Avatar
Touching My Member
ttt
Old Jan 31, 2006 | 12:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">just got an email from the guy and he said its the same, kool.
So the integra helms would have everything i need??</TD></TR></TABLE>
yeah it should have what you need.
hey vtecsyndrome, hows yur buddy doing on posts? The guy dat kant sppelll 4 chit.</TD></TR></TABLE>
ehhh the real sad part is that our real names are the same (Jay) oh man time for a name change.
Old Jan 31, 2006 | 12:25 PM
.Manny.'s Avatar
Touching My Member
kool, thanks for all the help everyone.
Sorry to hear about the name thing.
It really does take some effort to read the crap he types up.
Old Jan 31, 2006 | 12:27 PM
.Manny.'s Avatar
Touching My Member
oh before i forget. Ive tried the wiring diagram that i found on thezcr.com, why would this one not work for me?? Im esentially doing the same thing, im just bypassing the plugs. I dont want to fry the dizzy either.
BTW how would you be able to tell if the dizzy is fried? I opened it up and everything looked and smelled A OK.
Old Jan 31, 2006 | 03:10 PM
.Manny.'s Avatar
Touching My Member
hey guys, sorry to repeat myself, but how do i know if my new dizzy is fried????
Old Jan 31, 2006 | 04:56 PM
DelSolDon's Avatar
autozone can test your ICM if you take it to them, and you should be able to test the coil with a multimeter. i vote for going to the junkyard and cut your own plugs or contact rywire.com and see if you can buy just the plugs so that you don't run into this problem again.
Old Jan 31, 2006 | 04:58 PM
DelSolDon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">oh before i forget. Ive tried the wiring diagram that i found on thezcr.com, why would this one not work for me?? Im esentially doing the same thing, im just bypassing the plugs.
what engine harness are you using? are you looking at the right diagram for the right harness that you have?
Old Feb 2, 2006 | 09:25 AM
VegaS10's Avatar
Did you get this fixed?
My DK dizzy came in today, plugged it in and it worked great.
If need be, I can tell you what DK wiring corresponds with your engine wiring.
Let me know man.
douglaslovin
13
Mar 23, 2009 06:29 PM
sherfield2002
Dec 9, 2004 07:37 AM
cr-x si
Apr 8, 2003 12:42 PM
J98EX
Mar 11, 2003 10:29 AM
Stebo77
10
Dec 23, 2002 08:54 AM
