DEPO Fogs Replace Bulb?
Old Jan 30, 2006 | 09:56 PM
Mario.'s Avatar
Default DEPO Fogs Replace Bulb?
Is it possible to replace the bulb on DEPO fogs... or if they go out is a dead brick?
Old Jan 31, 2006 | 09:25 AM
Mario.'s Avatar
Default Re: DEPO Fogs Replace Bulb? (Mario.)
ttt
Old Jan 31, 2006 | 09:29 AM
splitime's Avatar
You can replace them, I swapped yellow Hella bulbs into mine when my normal bulbs died. Just spray the screws that hold the case together with pbblaster some before trying... mine had seized up and were a pain
Old Jan 31, 2006 | 09:39 AM
fms1day's Avatar
Default Re: DEPO Fogs Replace Bulb? (splitime)
Yeah be careful when taking off the screws in the back of the foglights. They're quite fragile even when you first get them. Once you take the back plating off, you can pull the bulb out just like you pull headlight bulbs outs. When you swap the bulbs make sure the positive and negative wires don't touch each other while bare. You'll create a short-circuit, like I did and blow the DEPO relay fuse. DEPO foglights are H3 bulb size.
Old Jan 31, 2006 | 12:55 PM
Newman's Avatar
New User
Default Re: DEPO Fogs Replace Bulb? (fms1day)
Just remove the fuse before you change the bulbs out and you won't have to worry about frying anything. They use H3 bulbs.
Old Jan 31, 2006 | 08:32 PM
Mario.'s Avatar
Default Re: DEPO Fogs Replace Bulb? (Newman)
Thank you!
I found out one of the wires actually ripped today so I have to remove the whole harness and resolder it.
*fun*
Thanks a lot guys!
sohcvtec91hatch
Oct 23, 2009 02:48 AM
Da1Gsr
Mar 6, 2006 07:03 PM
LudeChild
Mar 26, 2005 09:58 AM
jshi182
Dec 31, 2004 12:13 AM
