FS/FT: ALL OF MY BUILT D16 parts: ram-horn; forged internals; VTEC heads;blocks; rebuilt trans ETC
Ok guys; i'm ready to sell this **** finally. I need to get rid of most of it so i can finance my relocation out of this town
So i killed my last D series. took out a rod bearing when my wastegate line came off; boost cut was set too high. not enough oil to keep #4 rod from beating up the bearing. it's not spun but its beat up.
I have a b18a1 i'm building up now so i'm selling all my D parts. Here they are:
Current parts that were in the car:
250 - D16 ram-horn t3 flanged turbo manifold - internal gated turbo; external waste gate flange can be added for a fee - garunteed not to crack
75 - D16z6 block with endyn block posts - crank needs turning no internals
230 - d16z6 head complete w/ intake, B16 tb, obd1 distro, B&M fpr, - was in car - springs/valves were matched up, valve job done; NGK 1 step colder plugs with < 1k mi - will come w/ cam gear and z6 belt - great for mpfi/mini-me swap
150 - 8.5:1 D16Z6 SRP forged pistons std bore with rings (will get pics as soon as their out of the car)
175 - Eagle H beam D16 rods 3 good 1 iffy - arp200 rod bolts - the better ones (will get pics as soon as their out of the car)
275 - J&S Ultra Safeguard - with monitor and gm universal knock sensor - Individual cylinder knock control; great tuning aid keeps the motor from knocking by pulling timing from whatever cylinder is knocking
other D-series and random parts:
60 - d16z6 head in pieces needs some valves and vtec solenoid
50 - d16a6 head mostly complete has cam and all valves/springs but no manifolds or distro (was backup head)
50 - d15b2 shortblock - good (was my backup motor)
40 - d15b2 head complete - no manifolds or distro
20 - d16y7 intake manifold - missing tps
5e 20 for all - 6x -d16 rods w/ bad pistons
20 - stock d-series flywheel
25 - cable dx transmission - needs rebuild - swapped it out with above trans
40 - EF D-series shift linkage with short throw shifter
75 - Brand new autozone reman axles, just swapped out using lifetime warantee
75 - Dodge Neon half sized short radiator w/ slim fan filler neck and hoses - fits like eg half rad but not as tall.
50 - EG Half rad w/ cap
40 - 12" elecric slim fan
50 - B18A1 LS rods - 4 rods in great shape w/ original bearings with 3 bad pistons - estimated millage < 50k
40e - 2x 1g dsm SMIC
25e - 2x 1g dsm smic cores
20 - Autometer phantom mechanical oil pressure gauge w/ fittings and hardware - needs cleaning of the inlet the needle sticks some times, i think some teflon got stuck in there. I've cleaned it once with success
40 - Autometer phantom air/fuel pressure gauge used but great shape
30 - Autometer phantom electrical water temp gauge comes w/ hardware but NO sender used but great shape
40 - Autometer phantom elecrical EGT gauge and pyrometer probe - no control box - works AFAIK but without a box to test it i'm unsure
15e - 4-obd0 d16a6 peak-n-hold 240cc injectors
15 - 4-obd1 ls saturated 240cc injectors
60 - OBD0-OBD1 conversion jumper harness - built to your specs (meaning i have the parts and will build it if you want it)
Non-honda parts:
140 - Slim PS2 w/ all the usual accessories and MAdden NFL 06 game
175 - Pioneer SX-315 home theater in a box thing
100 - RadioShack Pro-95 dual trunk tracking scanner - well used but in good shape
Sold items:
SOLD - 50-D16a6 block w/ crank needs turning
SOLD - 60-D16A6 or d16z6 arp head studs
SOLD - 35-JG Engine dynamics D cam gear with key
SOLD - 175-Old style tuner toys/knockoff h beam rods - 77mm end cap can be shaved down to fit 75 or 75.5mm bore; NEW UNUSED with arp hardware
SOLD - 10-cable crx hf 4spd - probably good - was in car when i bought it; took it out when i got above tranny
SOLD - 40 - Autometer phantom mechanical 30" - 20psi boost gauge - used but great shape comes w/ hardware
SOLD - 60 - Knockoff SSauto/XS power 35mm wastegate - 4 or 8psi spring your choice. Used but in great shape; bought it as a spare; dont need it now. Does not come w/ ring seat or flanges, new ones are $20 for a tial 35mm and they will fit
SOLD - 20 - stock d-series clutches w/ pressure plates - little to no wear
SOLD - 25 - Japanese 10.3mm tripple core plug wires for D16Z6 but will fit other D's. less than 500mi on them - great wires
SOLD - 75 - Good condition 14b turbo no shaft play no evidence of oil leakage
SOLD - 125 - rebuilt cable d-series dx transmission - was in car less than 75 miles since rebuild - replaced a few worn bearings and input shaft seal; swapped out some syncro's from another tranny; swapped out the diff etc.
SOLD - 190 - XTD stage 3 clutch practically new w/ XTD 8lb flywheel - installed w/ rebuilt trans < 75 miles; not even broken in; never abused as its not broke in - great clutch love the light flywheel
Please note prices ARE NOT shipped and ARE NOT set in stone; i'm open to offers or package deals. I have a number of vouches on here; i've bought and sold from a number of people. I also have Ebay with 115 or so all posative feedbacks (username TSAudio). I am paypal verified with all posative feedback. you can reach me via pm here but i'd prefer you aim me at "honda of fury"
ALSO: IF YOU BUY SOMETHING AND ARE NOT SATISFIED I WILL WORK WITH YOU.
Here are a few pics, my dad took his good cam so I can't take more. I will get many more in the next few days
In this pic you can kinda see the gauges and the safeguard
Some trades I would accept are:
-B16 Cylinder head complete minus manifolds
XXX - LS forged rods
-LS forged pistons
-Any LS buildup parts really
xxx - vtec b series oil pump
-b series cable trany or aftermarket clutch/flywheel
-ETC b series parts
-EF B series swap parts (mounts/axles/shift linkage/etc)
Modified by Pay2play killa at 4:13 PM 3/8/2006
Non-honda parts:
Sold items:
-LS forged pistons
-ETC b series parts
Small update guys. I've spent the last couple of agonizing hours in the hospital so I haven't gotten anything taken out today. My best friend from high school crashed his bike today and wasn't wearing a helmet. They dont think he'll make it so i'm at a loss right now; my brain has shut down.
I probably wont get around to tearing this **** out for a while unless something miraculous happens so i'm sorry those of you who are interested and waiting. It will happen eventually though; i may work on it to keep my mind off of things later but for now I'm not sure.
Anyway; to those of you who have bikes; USE YOUR ******* HELMET
sorry to hear about your friend yo... as i speak for all of us. honda-tech gives our best wishes to you and his friends and family. i am interested in most of your parts. but i can wait for time to pass.. pm me when everything is cool.. otherwise goodluck bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">is the clutch hydro</TD></TR></TABLE>
it will fit any d-series transmission. only differnece beetween the years is the throwout bearing
Greg H
Feb 20, 2011 09:16 AM
psycheus
Jun 11, 2008 03:45 PM
psycheus
Jun 10, 2008 07:27 PM
Pay2play killa
Texas -OK -LA (Sales)
Jun 1, 2006 10:05 PM
Pay2play killa
Jun 1, 2006 10:04 PM
