Getting a stock CRX cable cluster to work with B swap ?
Is it possible ? All I have to do is get a cable VSS, correct ? The Ecu has to know the speed, so if there a wire that I can tap into on the cluster that will give a speed reading ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar »</TD></TR><TR><TD CLASS="quote">no need to modify. just use a cable vss for the b series</TD></TR></TABLE>
In that case, F**k the gsr cluster project. the crx cluster goes up to 8K anyway, and it will be fun to see the looks on peoples faces when I rev it almost 3K over the (stock) redline.
Looking for a 88-89 CRX cluster, and dash harness...
or if you want a cheap GSR cluster w/plugs and 90% complete modified dash harness pm me
What cable VSS works ? a DA integra one I assume ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr »</TD></TR><TR><TD CLASS="quote">
What cable VSS works ? a DA integra one I assume ? </TD></TR></TABLE>
You meen the actual part that goes on/in the tranny right? any 90-93 DA or 88-91 5spd VSS should work, I have a '92 Teg on my ys1 tranny. You just need to run the same cluster as the VSS you run, cable cluster=cable VSS and electric VSS=electric cluster
Any cable will work....Just Remember to Be careful setting the Vss back into the Tranny. And Don't don't dont' don't forget to put your C-Clip on correctly....Pull the cable up and down a little bit to make sure it fits in that groove thing or mid drive....No more Rpms. Bummer...
And yes the gs-r may be what everybody is doing but I love watching the passangers face when i dip 3 numbers in the red...and my HF shiftlift Turns on at 7800. It's a total HF thing. Good times to be had. Good luck....And anything above 92 tranny has E.VSS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">..And anything above 92 tranny has E.VSS.</TD></TR></TABLE>
except for the 92-93 GS-R and ys1s around the world
for civics that is true 92-up=E.VSS
wrong! the ecu recieves the speed signal from the cluster, not the tranny. So if you're speedo works (via cable) thats all that matters. now if you had a hydro tranny with an electric VSS we would be in a whole new ball game.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr »</TD></TR><TR><TD CLASS="quote">In that case, F**k the gsr cluster project. the crx cluster goes up to 8K anyway, and it will be fun to see the looks on peoples faces when I rev it almost 3K over the (stock) redline.
or if you want a cheap GSR cluster w/plugs and 90% complete modified dash harness pm me</TD></TR></TABLE>
it dont keep up to good, really it sucks mine is about 700 off in high rpm
ben.batiste
Jan 7, 2010 07:20 AM
