Car turns over but wont start.. any suggestions (00 civic si)
Old Jan 30, 2006 | 08:01 PM
Ls_V_TurboSi's Avatar
Default Car turns over but wont start.. any suggestions (00 civic si)
Well I just put this motor in the car yesterday and last night it fired up just fine. I went out this morning to bleed the brakes and coolant and it wouldnt start..
So far I've replaced:
Ecu
Spark plugs
plug wires
Distributor
I can here the fuel pump prime and when I took the spark plugs out there smelled like gas so I know its getting fuel and I checked to see if its getting spark and it is. I'm not really sure what else to do. Any positive input is appreciated
Old Jan 30, 2006 | 09:21 PM
ILUVMYEM1's Avatar
Default Re: Car turns over but wont start.. any suggestions (Ls_V_TurboSi)
r u sure it doesnt have diesel in the tank.... check if the spark plugs are getting spark to them..... take out the wire and the plug, then put the plug on the wire put it on metal and crank it to see if it gives like 3 sparks.... it could also be a coil.....
Old Feb 1, 2006 | 10:56 PM
Swapped_EG's Avatar
Check to see if a ground came loose. Sometimes its the simple things that get you.
Old Feb 1, 2006 | 11:01 PM
urnotfast's Avatar
Default Re: (Swapped_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swapped_EG &raquo;</TD></TR><TR><TD CLASS="quote">Check to see if a ground came loose. Sometimes its the simple things that get you.</TD></TR></TABLE>
happened to one of my friends before. sometimes you overlook something small in search of something big
peace
eric
Old Feb 2, 2006 | 07:45 AM
broly12phoenix's Avatar
i had the same problem except it was in my honda passport, took it to honda and they replaced a batterie cable and the battery, before that it would crank and not turnover, thought it was alternator check batterie and cables and alternator.
All i can think of.
Best of luck to you!
Old Feb 2, 2006 | 07:49 AM
DRAMA's Avatar
Also you can unbolt the fuel line to the rail and see if fuel actually comes out just to make sure your engine is getting fuel. Might be a clogged fuel filter.
Old Feb 2, 2006 | 08:20 AM
whitelightning's Avatar
is your timing correct? check your ignition coil too
all the grounds okay?
Old Feb 2, 2006 | 08:53 AM
cambam20's Avatar
I just had this same **** with my del sol it was the gound! but tell I fixed it the car would not turn over ! so your gounds . check the spark and fuel, how long have you not drove it? coils go out slowly
Civic Hybrid
10
Aug 17, 2008 09:35 AM
Hondaciv95VX
Mar 21, 2007 07:53 PM
GoldCoin
Aug 21, 2006 06:29 PM
skata89
May 21, 2006 03:32 PM
raczyk
Dec 19, 2005 04:01 PM
