90 DX Dist. on 91 CRX SI
Old Mar 24, 2002 | 11:28 AM
blayzenazn's Avatar
Default 90 DX Dist. on 91 CRX SI
can I put a 90 CRX DX Distributor on my 91 CRX SI??? Will it work???
Old Mar 24, 2002 | 11:31 AM
CRX-RX's Avatar
Default Re: 90 DX Dist. on 91 CRX SI (blayzenazn)
Not at all
Old Mar 24, 2002 | 11:39 AM
89 CRX SI's Avatar
Default Re: 90 DX Dist. on 91 CRX SI (CRX-RX)
You would have to add lotz of duct tape. JK IT WONT WORK
Old Mar 24, 2002 | 12:13 PM
JDM HYBRID's Avatar
jon, i think i can get an si dist. ima ask my boy john with the ZC....he gotta extra motor....let me know whta u doin...
Old Mar 24, 2002 | 12:30 PM
Jonathan_ED3's Avatar
what in the world are yall talking about? i've had the same dizzy on a 91 Si, took it off put it on a 90 DX, and then i even put it on a 91 STD...worked/bolted up fine on all of them?
Old Mar 24, 2002 | 12:56 PM
blayzenazn's Avatar
Default Re: 90 DX Dist. on 91 CRX SI (JDM HYBRID)
Im putting that 92 LS motor in my CRX, but I need a 90-91 Integra Dist. for it to work...I was going to put the SI Dist. on the LS motor, and sell the SI motor to Walter...now Walter isnt going to get my SI Dist., so I need to know if he can put his DX Dist. on my SI motor?
Old Mar 24, 2002 | 12:57 PM
i'm telling you. i took my dizzy of my 91 Si..put it on my friends DX...and i've also had it on an STD..worked fine with all of them.
Old Mar 24, 2002 | 01:07 PM
Aphrodavid's Avatar
you can use a DX dist on an SI and vise versa, but you have to rewire 2 wires(crank angle sensor, cant remember the other one).
Old Mar 24, 2002 | 06:00 PM
ShiroX's Avatar
Default Re: 90 DX Dist. on 91 CRX SI (DX-R)
does any of you all have an si distributor you want to sell me? an hf will work also
Old Mar 24, 2002 | 06:47 PM
CRX-RX's Avatar
Default Re: 90 DX Dist. on 91 CRX SI (VTeC4TheChildren)
Rewire?????? With what? there are two wires missing, that's the whole point!
Old Mar 24, 2002 | 07:43 PM
Aphrodavid's Avatar
yea, what would i know, i only have a 91 SI dist on my 90 DX motor. and i only put a 90 DX dist on my friends 90 SI motor.
Old Mar 25, 2002 | 01:14 AM
CRX-RX's Avatar
Default Re: 90 DX Dist. on 91 CRX SI (Aphrodavid)
Honestly, I would like to know how?? The DX dist. only has six wires with a square plug, like a ZC plug, where the SI has a round plug with 8 wires. Where did the extra two come from?? According to the factory service manual for an 88 CRX, as well as the manual for a 91 CRX, the DX distributor is missing a blu/yel, and a blu/grn wire, both of which are for the Cylinder position sensor, that is completely missing from the DX dist. Seeing how it does not contain this sensor, how did you magically make it apper inside?
[Modified by CRX-RX, 4:21 AM 3/25/2002]
Old Mar 25, 2002 | 08:00 AM
maximedx's Avatar
yes where are the cylinder position sensor.
Old Mar 25, 2002 | 12:53 PM
therealciviczc's Avatar
Why don't you just trade distributors?
Really though. Does the DX dist have the cyl pos sensor in there, just not wired or something? I know that the DX dist that I've seen only have the six five wire plug.
kekekekevin
Apr 27, 2007 07:27 AM
97grnrs
Mar 17, 2007 01:49 PM
tigueremalo
May 31, 2006 01:08 PM
tibs
Jul 21, 2005 08:29 PM
