KYB GR-2 shocks, who has em?
Old Jan 30, 2006 | 07:29 PM
uneek4dr's Avatar
Default KYB GR-2 shocks, who has em?
Anyone riding on these shocks? I havent decided if I need adjustable shocks to spend the extra $125 on the AGX shocks. Any opinions on the GR-2?
Old Jan 30, 2006 | 08:07 PM
xbn83's Avatar
Default Re: KYB GR-2 shocks, who has em? (uneek4dr)
GR2 is like OEM replacement. Get AGX. I'm running AGX now, very good.
Old Jan 30, 2006 | 08:57 PM
Nipsey Hussle's Avatar
i got them with neuspeed sport springs they work out ok however something stiffer would do the job i would rate them slightly better than stock but good for the money if you do want to handle better I would spend a little more and get better to be honest with the prelude being heavy with this set up you definatley will feel some body roll if you need a quick solution to shocks and struts then this is it.
Old Jan 30, 2006 | 09:45 PM
Skidtron89's Avatar
The fronts will blow in months they are not designed to operate at the height a lowering spring puts them at. They are for OEM replacement only. Get the AGXs I've had them on this Prelude I have now for somewhere between 3-4 years and they are still as good as the day I got them. Well worth the extra duckets.
Old Jan 31, 2006 | 06:22 AM
uneek4dr's Avatar
AGX it is
Old Jan 31, 2006 | 06:31 AM
ThE PiMpiN Co's Avatar
Default Re: (uneek4dr)
The GR2's aren't bad, it'd be more of if you're on a budget type setup... if you want ultimate performance, your money would be best spent elsewhere though. Have you looked into getting some Koni's?
Old Jan 31, 2006 | 10:24 AM
uneek4dr's Avatar
yeah but ive heard the AGX is a great shock to, i just dont need adjustable dampening so i thought the GR-2's might be a good alternative, but if they go out in a few months i might as well spend the extra money now and get the agx's. Also the AGX's are about 150 less than koni yellow's
Old Feb 1, 2006 | 05:47 PM
djbrandonr's Avatar
I had agx's alla round till the rear pass blew. So now I got agx in the front and gr2's in the back cause it fit my budget. The gr2s are better than stock, but not as good as the agx's but I had to get wha ti had to at the time. The agxs are easy to change and feel good
Old Feb 1, 2006 | 07:12 PM
Default Re: KYB GR-2 shocks, who has em? (Skidtron89)
ive had mine for months havent blown yet i had them with coil overs with no gaps and then put the nuespeed sport springs and they are still strong
Old Feb 1, 2006 | 08:21 PM
uneek4dr's Avatar
did you get a 2" drop out of the springs or does it sit a little lower with the GR-2's?
Old Feb 1, 2006 | 08:33 PM
one finger gap in the front and just about a two finger gap in the rear
Old Feb 2, 2006 | 08:58 PM
Skidtron89's Avatar
Default Re: KYB GR-2 shocks, who has em? (Negrodamus)
That's great so you had coilovers and gr2's on your car huh? can you say baja? Are you planning to put rancho shocks on next. YOU DID NOT HAVE COILOVERS THEN YOU HAD CRAP SUCH AS THE FOLLOWING: Ground control (Sorry to break your heart these are not coilovers) OBX racing adjustable sleeves=junk, skunk 2 adjustable sleeve=junk, etc Coilovers have struts that are valved for the spring rates they come with. They are made by company mostly in Japan they usually cost at least $600 for base model **** mostly anything worth having is $800-$3000
Watch out for the cactus!!
ragethemachine86
Suspension & Brakes
Jan 21, 2007 08:24 AM
bigBOI_92DA9
Aug 31, 2005 06:30 AM
aleks77
Jun 2, 2005 08:54 PM
Bryan-95prelude
Nov 8, 2004 05:52 AM
