LS VTEC B16 or GSR Head
Old Jan 30, 2006 | 05:04 PM
MxJones92's Avatar
Default LS VTEC B16 or GSR Head
Obviously the GSR head is a better head, but if you were building an LS VTEC on a budget if you could get a b16 Head for 500 or a gsr for 900 which one would be a better route.
Old Jan 30, 2006 | 05:08 PM
mluckxxx's Avatar
Default Re: LS VTEC B16 or GSR Head (MxJones92)
bite the bullet and pay the 900 now, you'll be wishing you did
Old Jan 30, 2006 | 05:13 PM
tsdenny's Avatar
gsr got two stage vtec
not sure what the b16 has
Old Jan 30, 2006 | 05:37 PM
GetawayInMoscow's Avatar
Default Re: LS VTEC B16 or GSR Head (void_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by void_accord &raquo;</TD></TR><TR><TD CLASS="quote">gsr got two stage vtec
not sure what the b16 has</TD></TR></TABLE>
b16 has 3 stage so you really hit vtec 3 times in every gear
Old Jan 30, 2006 | 07:29 PM
Out of every
Default Re: LS VTEC B16 or GSR Head (GetawayInMoscow)
hahah
Old Jan 31, 2006 | 07:22 AM
gotboostedvr6's Avatar
900 is alot for a gsr head if it is stock, is that with the intake manifold and dizzy?
Old Jan 31, 2006 | 08:01 AM
Jay_Sensing's Avatar
Obviously it all depends on what you are trying to do as well man, a GSR head will have higher compression than a B16/B18C5 head but it will not flow as well. At max lift, a B16 head and a B18C5 head flow within a couple of cfm of each other as they are cast from the same mold. The only differences between the two from the factory is a MILD port job on the R head and dual valve springs.
In my opinion, the B16 is a better option and the GSR for both price and maximum power output.
Old Jan 31, 2006 | 08:58 PM
Z32Z06's Avatar
Default Re: (Jay_Sensing)
yeah i heard the type r is almost the same as the B16 head
and a lot of people use the B16 head and just build the head the right way
Old Jan 31, 2006 | 09:53 PM
toeknee360*'s Avatar
Default Re: (Z32Z06)
gsr! http://www.importreview.com/re....html
Old Feb 1, 2006 | 09:18 AM
MxJones92's Avatar
Default Re: (kt*)
right on good link. thanks. does the b16a head have the same stud locations and dowel problems as the gsr head
Old Feb 1, 2006 | 10:12 AM
d16vtecx's Avatar
Default Re: (MxJones92)
yes
patrickracing
14
Aug 19, 2010 01:11 PM
ProjectEF9SI
Feb 17, 2007 04:20 PM
hatchvtec
13
Jun 18, 2006 11:48 AM
686_ef
Mar 3, 2005 05:03 PM
OreoEF8
27
Aug 20, 2004 10:16 PM
