Compression Ratio
Old Jan 30, 2006 | 03:14 PM
user 931176363637's Avatar
Default Compression Ratio
As well all know inside the 90-93 model year accord lies the F22 with a compression ratio of 8.8:1. This is low, for N/A, but this seems to be perfect to support a turbo running around 8ish psi. Is this correct to say, because I also have read on other posts that you should get 9.5:1 pistons with the turbo. But iam not too into blowing my head. What is going on here?
Thanks, Scott
Old Jan 30, 2006 | 03:52 PM
iam7head's Avatar
Default Re: Compression Ratio (93Accord117)
high compression+boost in aluminum honda block=3month of fun
Old Jan 30, 2006 | 04:42 PM
P_Adams's Avatar
9.5:1 Compression ratio is considered the absolute highest ratio which should be considered for Turbocharging. 8.2:1 to 8.8:1 is considered closer to ideal.
It's all about detonation, and what you've got to do to control it.
When you start at a lower c/r, you can dial additional boost to gain back the H/C advantage and still gain some b4 you have to worry about timing , water injection, methanol additives and custom a/f curves.
8.8:1 is a good place to start.
P
4genaccordfreak
Apr 30, 2014 06:28 PM
99siRACER
Jan 3, 2012 12:20 AM
TehMoonRulz
May 16, 2005 01:15 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
dontcare61776
Apr 7, 2002 09:27 AM
