third gear grind
Old Jan 30, 2006 | 03:14 PM
aquabob89's Avatar
* B A N N E D *
Default third gear grind
If i were to change my transmission fluid would it get better or prevent other synchronizers from going out. or should i just get new synchronizers.
Old Jan 30, 2006 | 03:19 PM
LOLyouhavefakewheels's Avatar
Default Re: third gear grind (aquabob89)
I had a little grind in 3rd gear once I changed my fluid and it is smooth now. It depends on how bad the syncros are and what fluid you are using. I would change the fluid and if still happens then change the syncros
Old Jan 30, 2006 | 03:22 PM
aquabob89's Avatar
* B A N N E D *
Default Re: third gear grind (CivicB18C5)
if i change the fluid its going to be oem honda stuff. its suppose to be the best
Old Jan 30, 2006 | 03:24 PM
tallyturbo's Avatar
try syncromesh. that might help.
Old Jan 30, 2006 | 03:32 PM
aquabob89's Avatar
* B A N N E D *
Default Re: third gear grind (tallyturbo)
sounds good thanks for the input
Old Jan 30, 2006 | 03:36 PM
civic_driver_389's Avatar
You could also use redline fluid. That stuff works good
Old Jan 30, 2006 | 03:37 PM
egyolk's Avatar
Default Re: third gear grind (civic_driver_389)
if u want a temp fix, try gm syncromesh, it has to be friction modified, look it up theres like 100 post's about the wonders it works.
_decker
Oct 9, 2017 06:42 PM
honda.girl.1991
Jan 16, 2014 08:36 PM
selfmade0086
Transmission & Drivetrain
Jun 3, 2013 07:12 PM
BB1 pOwA!!
Aug 24, 2007 11:03 PM
