Cluster, Turn Sisgnal and Clock all stoped working
Old Jan 30, 2006 | 02:36 PM
LOLyouhavefakewheels's Avatar
Default Cluster, Turn Sisgnal and Clock all stoped working
As the title says, my cluster lights still work and my hazard lights still work so its not the relay. I checked all my under hood and underdash fuses and they're all fine. Is there a fuse that controls the cluster, signals, and clock. The car is a 1995 Civic Si-R (Japanese model)
Old Jan 30, 2006 | 02:45 PM
mrbigg9032's Avatar
I would defianalty check the fuses again because thats what it sounds like.
Old Jan 30, 2006 | 03:16 PM
Default Re: (mrbigg9032)
I checked each fuse about 3 times now and they're all good. My back up lights are also not working but my back up fuse is fine. From the research that I've done i think I have a bad ground, but I have no idea where the ground cable is for the signals.
Old Jan 30, 2006 | 04:28 PM
Default Re: (CivicB18C5)
Anyone????
Old Jan 30, 2006 | 04:54 PM
Ross 2.0's Avatar
In a Junkyard near you.
Can you give me a VIN # so I can get the appropriate diagram?
Old Jan 30, 2006 | 05:17 PM
Honda_Cribb_GS-R's Avatar
me and my cousin found out one night(the hard way off takin the dash apart) that the hazard switch controls the turn signals,cluster lights, and radio bezel light
Old Jan 30, 2006 | 05:19 PM
Ross 2.0's Avatar
Your right the switch is after the relay so it's probably good. I would suspect the switch itself because each light has it's own ground.
Does the clock do anything at all?
Old Jan 30, 2006 | 05:29 PM
Default Re: (MooGoCow3)
No the clock doesn't turn on at all, same with the reverse lights.
Old Feb 1, 2006 | 06:57 AM
I installed a whole new gauge cluster and it still isn't working. Is there a fuse or a ground that the signals,cluster, reverse lights, and clock are hooked up to? I'm pretty sure thats my problem.
Old Feb 1, 2006 | 11:46 AM
riceburnerryan's Avatar
are the fuses in the engine bay fuse box good as well?? there is a back up fuse, i would check that
Old Feb 1, 2006 | 01:09 PM
Default Re: (riceburnerryan)
Yea I replaced the "back-up" fuse under the hood and still nothing.
Old Feb 1, 2006 | 07:28 PM
Fixed it finally Ended up being a loose wire on the back of the fuse box under the dash. Thanks for the help though
looxs
11
Feb 5, 2007 04:06 PM
JDMlyfestyle
Nov 20, 2005 07:21 PM
frankfezzie
35
Oct 25, 2005 09:46 PM
prelude1897
Apr 27, 2005 11:09 AM
BrynnTheSlut
Aug 7, 2003 09:14 AM
