Where is the PCV valve on a 97 HX?
I was going to change out my PCV cause my car doesn't idle as smooth as I would like, but I can't find the damn thing. I know it has to be in a vacuum line between the valve cover and the intake, but still can't find it.
See the hose attached to the intake manifold that goes down under manifold in the center? And see the one thats connected to the valve cover going to your intake arm. Both of those are your PCV system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports »</TD></TR><TR><TD CLASS="quote">ur timming is wrong on ur dizzy if thats ur car</TD></TR></TABLE>
Looks like maybe a messed up timing belt job. Maybe a tooth off. Idle problem may be a little bit deeper than the PCV.
Modified by ChrisC_ at 9:10 PM 1/30/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisC_ »</TD></TR><TR><TD CLASS="quote">Likes like a messed up timing belt job. Maybe a tooth off. Idle problem may be a little bit deeper than the PCV.</TD></TR></TABLE>
I advanced the timing all the way and it helped out with the idle a little. But I did that a long time ago. How do you figure its the cam timing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20civic00 »</TD></TR><TR><TD CLASS="quote">u have a 97 HX? I thoght the HX's didn't come with AC?...</TD></TR></TABLE>
No the HXs came with everything the LXs do, except cruise.
RiversideS13
Jul 18, 2007 11:08 AM
. im sure it cant be that much diff than ur car
