Pulls left when accelerating
Old Jan 30, 2006 | 07:57 AM
dpkelly's Avatar
Default Pulls left when accelerating
1992 civic hatch, dx, 5-spd. Anyone have an idea why it pulls left when accelerating? It doesn't pull at all when decelerating. I think my bushings are shot. Which bushings in particular should I check?
Old Jan 30, 2006 | 08:16 AM
tpr's Avatar
tpr
Default Re: Pulls left when accelerating (dpkelly)
Check your outer tierod ends. Most likely the right side is worn out. If they are good then check your lower ball joints, last and least likely the upper ball joints.
Old Jan 30, 2006 | 08:30 AM
sh!tsWEAK!'s Avatar
Default Re: Pulls left when accelerating (tpr)
Check your tie rod ends ASAP!!! Last summer, my car started pulling to the right when I would accelerate and I had no idea why. Then when i was taking my car around a slight turn I heard a loud crunch and the car stopped. I get out, my wheel was bending inwards. Previous owner did not use proper cotter pins because the bolt came undone and I ended up with a damaged tie rod end that came loose and scratched up the inside of my wheel, a broken axle, and also I had to replace the lower ball joint because the threads on it got stripped . Do not drive, get it fixed asap.
Old Jan 30, 2006 | 08:33 AM
dpkelly's Avatar
Default Re: Pulls left when accelerating (TopSecretEg6)
Thanks sounds like tie rod ends. What's a quick test to check this out?
Old Jan 30, 2006 | 08:41 AM
Hondaciv95VX's Avatar
Tug on the wheel, in and out. See if there is any give.
Reyracer19
Jul 22, 2010 09:38 AM
ragnarok0mega
Jul 11, 2009 08:51 PM
rodneylynn1977
May 10, 2009 10:27 PM
preluderemis
Mar 18, 2009 05:13 PM
ke98248
Oct 23, 2007 12:10 PM
