big problem at high speeds???need help
Old Jan 30, 2006 | 07:10 AM
bb6_lude's Avatar
Default big problem at high speeds???need help
ok i have a eg with a jdm b16a swap. it runs great through the gears 123 but around 100 mph it wont pull through vtec anymore and in fith gear around 100 it seems to miss fire or something. seems to me as a distributor problem or fuel???io have no idea.. please help. if you need more info then ask. thanks alot.
Old Jan 30, 2006 | 07:17 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: big problem at high speeds???need help (i_heart_EG)
hows the clutch?
Old Jan 30, 2006 | 08:19 AM
bb6_lude's Avatar
Default Re: big problem at high speeds???need help (boostedcivicsir)
just replaced clutch and flywheel
Old Jan 30, 2006 | 05:51 PM
bb6_lude's Avatar
dump.
Old Jan 31, 2006 | 02:22 AM
bb6_lude's Avatar
morning bump. HELP!
Old Jan 31, 2006 | 03:45 AM
bb6_lude's Avatar
1st period bump.
Old Feb 1, 2006 | 02:23 AM
bb6_lude's Avatar
bump....please help. any idea?
Old Feb 1, 2006 | 03:29 AM
bb6_lude's Avatar
another first period bump...
Old Feb 1, 2006 | 06:34 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
doesnt that motor and ecu cut out at 110 ? or something i heard u cant go past 110 or something limiter or something maby its that...
Old Feb 1, 2006 | 06:44 AM
dso's Avatar
dso
Default Re: (RED_90TEG)
nah i have a b16a2 n i've taken mine over 130 so it shouldn't be that, unless you're he's using a diff ecu than i am???
Old Feb 1, 2006 | 08:46 AM
92redhatch's Avatar
its definatelyyour distributer! Guranteed! Do you have an MSD???? I had the same problem when i connected my MSD. the wires that went to the igniter would keep getting loose. Take off your distributer cap and look at the wires. It should be that.
Old Feb 1, 2006 | 09:37 AM
92ehatch's Avatar
Default Re: (92redhatch)
it shouldnt be cutting fuel at that speed, but i dont see how much its gonna actually pull at that high of speeds, especially in 5th gear.
and i hope your not doing those speeds on the highway
please tell me thats on the track
Old Feb 1, 2006 | 09:44 AM
bb6_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RED_90TEG &raquo;</TD></TR><TR><TD CLASS="quote">doesnt that motor and ecu cut out at 110 ? or something i heard u cant go past 110 or something limiter or something maby its that...</TD></TR></TABLE>
no ive taken it past that...just started happening recently.
Old Feb 1, 2006 | 09:45 AM
bb6_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">its definatelyyour distributer! Guranteed! Do you have an MSD???? I had the same problem when i connected my MSD. the wires that went to the igniter would keep getting loose. Take off your distributer cap and look at the wires. It should be that.</TD></TR></TABLE>
no the distributor is stock...but it might be loose wires. ill check.
thanx for the posts guys
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_heart_EG &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a eg with a jdm b16a swap. it runs great through the gears 123 but around 100 mph it wont pull through vtec anymore and in fith gear around 100 it seems to miss fire or something. seems to me as a distributor problem or fuel???io have no idea.. please help. if you need more info then ask. thanks alot. </TD></TR></TABLE>
well 4th and 5th gear arent supposed to pull like the other 3. but if it literally wont go past your 100 mph mark regardless of what you do then its not fuel. do you have a huge body kit that air can just get caught up in a slow you down??
I dont know how it would be ignition cause that isnt related to speed as it is rpm.
Old Feb 1, 2006 | 05:50 PM
bb6_lude's Avatar
Default Re: big problem at high speeds???need help (1dumbassscreenname)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dumbassscreenname &raquo;</TD></TR><TR><TD CLASS="quote">do you have a huge body kit that air can just get caught up in a slow you down??
no.
Old Feb 1, 2006 | 06:07 PM
92hatchling's Avatar
at ecu are you useing??
Old Feb 1, 2006 | 07:18 PM
dso's Avatar
dso
Default Re: (93cb7sedan)
yea fifth gear doesn't pull that hard, but you'd be surprised with the pull fourth gear has, i know i was.
Old Feb 1, 2006 | 07:23 PM
Archidictus's Avatar
Unceasing Measure
Why the expletive are you going 100+ miles per hour to begin with? I know your shitbox B16 Civic doesn't trap near there in the quarter.
Old Feb 1, 2006 | 07:45 PM
dso's Avatar
dso
Default Re: (Archidictus)
personally because i'm an idiot and had to learn the hard way.
Old Feb 1, 2006 | 08:04 PM
EG-Tony's Avatar
Old Feb 1, 2006 | 10:46 PM
TurboEKcoupe's Avatar
Default Re: big problem at high speeds???need help (EG-Tony)
hmm it shouldnt be cutting out like that we had my friends b16a jdm swap in his rex at about 135 check your dizzy
Old Feb 2, 2006 | 02:31 AM
bb6_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Why the expletive are you going 100+ miles per hour to begin with? I know your shitbox B16 Civic doesn't trap near there in the quarter.</TD></TR></TABLE>
highway racing...
Old Feb 2, 2006 | 02:50 AM
boostedek9's Avatar
1, shitbox...I think not sir...2, wtf is your amazing show car at?..oh wait, let me guess...its busy at sema or HIN. Dont talk trash about peoples cars, and irrelivant to where he was doing 100, 200, 500 mph..it doesnt matter if he was on the track or the bonnevile salt flats...stop running your *** catcher unless you want to help the kid out. Personally I think its a ignition problem patty...good job posting this for kev
Old Feb 2, 2006 | 03:35 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (boostedek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedek9 &raquo;</TD></TR><TR><TD CLASS="quote">1, shitbox...I think not sir...2, wtf is your amazing show car at?..oh wait, let me guess...its busy at sema or HIN. Dont talk trash about peoples cars, and irrelivant to where he was doing 100, 200, 500 mph..it doesnt matter if he was on the track or the bonnevile salt flats...stop running your *** catcher unless you want to help the kid out. Personally I think its a ignition problem patty...good job posting this for kev</TD></TR></TABLE>
whew, a little emotional here yea?... but i agree with the ignition problem, cap/rotor/plugs/grounds
