quick . Will a s20 LSD box off a d15b fit my d16a8 ?
yep , quick one !
Will the s20 gearbox off a d15b (LSD equioed) fit my d16a8 (with my stock driveshafts) ?
i know the gearbox will bolt up , jsut not sure wether the driveshafts will be too big or jsut right.
thanks ben !
thanks ben !
if you are taling about a d16a6, yes, but with premis.
the lsd is ring gear dependent, meaning, the lsd must match the ring gear. I amnot sure if the d16a6ring gearhad the same bolt pattern. If not, then you have to use the s20 ring gear and counter shaft.and REV.( i think rev is all the same)
then you can transfew all the gears over.
a d15bx FD is terrible, and there is absolutrely no reason why you would want it, unless you are putting out over 400 hp
for the record, (pulling this out of archvies) but it will work IF and only IF you have a 4.25 final drive.
cable 4.25 countershaft + hydro lsd with the 4.25 LSD ring gear = will work
