94-01 Integra dash swap in progress
Well I started my research last week and got started over the weekend on this little project for my rex. Its coming along quite well. So far I have removed the dash, all the heating and a/c boxes including blower and dropped the steering column. For the dash to fit, the spot behind where the gauge cluster sits needs to be cut down quite a bit. Also the vents on the sides need to be cut down.
My main concern now it making sure all gaps are sealed. As it is now I have no vents or heat but as soon as I have everything to where I want it I will start on that.
I do however need to know if anyone else who has done this has any pictures of the custom brackets they made with dimension. I'd like to start on those today because I plan to be done the fitment in a few hours. I have read through all the previous posts on this but have not seen any pictures of them, just think it would make my job easier instead of starting from scratch.
Thanks alot.
Thanks alot.
Hi. I once had a 93 Teg dash in my CRX. It was a lot of works. But once I have it done, I regretted doing it. So, I have to take it back out and put the stock dash back in but, still keeping the cluster. But, as for brackets, i used the right hand side bracket from the Teg (on the lower part of the A pillar) and the Crx's left mount. Sorry not much help here. Just trying to let you know how it came out for me. Later, and good luck on the swap.
Sorry about post pictures, I started a new job and I am traveling alot, leaving for Mississippi in the morning. The car is at my friends house and is about an hour away so its tough to get a chance to work on it. As soon as I can though I'll post pictures and try to make a nice write-up of it.
B18Cej1
Feb 11, 2004 03:31 PM
