Engine swap for CRX
Wiring (if you brave and do it yourself it's cheap, if your not, it's not so cheap).
It's pretty simple. B series kit for EF civic/CRX. ECU, Axles and the actually engine and tranny itself. The rest is butter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotboxedcrx »</TD></TR><TR><TD CLASS="quote">Search you freaking idiot... print out the procedure and dont ask such damn basic questions
So on to the topic, here's a link to the hasport install manual for their b-series motor mounts, it'll tell you a good bit: http://www.hasport.com/Tech/Hasport%20.htm
EFB1 = kit for cable trannys
EFB2 = kit for hydro trannys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KL14 »</TD></TR><TR><TD CLASS="quote">
EFB2 = kit for hydro trannys</TD></TR></TABLE>
haha another Noob vs Noob...
Yes just check the search function and these posts will be unnecessary. This is the most common topic on this forum, you will spend days searching through all the info on this subjectt.
streetimports.com has yonaka mounts. they are inexpensive copies of the old hasport mounts. i like mine very much.
http://www.streetimports.com/p...d=365
Yes, finally i got the answer i want to read! i saw this too but didnt know if they can be trusted since iz online shop (hassle on shipping and return things) Im gonna use GSR tranny tho. tell me abt the product (how good are they compare to hassport), do they fit and last decent?
they are very good mounts. good fitment. the engine wasnt too low, or too high. i did have to notch my hood a little bit. i dont think they have a kit if you want to use a hydro gsr tranny. if thats the case, then i would probably just shell out a little more for the hasport kit.
illcrx
18
Mar 12, 2005 12:12 AM
