Need Help With ECU : What Wire Is This? (Picture)
So I went under the carpet tonight to check out my ecu.
First question is : What wire is this?
Sorry for such a big picture. I did resize them but I had to leave them big enough so you guys could see what wire im talking about.
And Here is another picture.
And my second question is how do I figure out what ECU I am running?
Thanks
Thanks
not sure about the wire off the top of my head. if you look on the side or your ecu, there will be a sticker with a bar code on it. there will also be two serial numbers. in the middle of the dashes on the top number will be the code of your ecu. it will be like p72 p73 or p06 whatever.
Youll have to open the ecu and show us pictures of the inside. If you like you could bring the car by and i could look at it and tell you how to read pins and figure whats what. LMK.
vtec solinoid isnt on the d plud only vtec pressure switch. im not seeing any blk/blu wire on d plug they might have repinned it. count the location of the wire on the plug. looking from the back.
BlueShadow
Jun 1, 2005 10:08 PM
AndyD
Jun 3, 2004 04:38 AM
