OBD0 to OBD1 help
I'm turboing my ls crx and I need to get it tuned. I have a chipped P28. If I convert to OBD1 do I need the OBD1 dizzy too, or just the ecu, jumper harness and 4 wire o2.
Thanks lot,
Chris
Thanks lot,
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEgHatchFl »</TD></TR><TR><TD CLASS="quote">I still need the OBD1 dizzy, jumper harness and 4 wire o2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEgHatchFl »</TD></TR><TR><TD CLASS="quote">But I can't use the obd1 dizzy right? How hard is it to wire the 4 wire o2 in?</TD></TR></TABLE>
you can use an obd1 or obd2 dizzy. For the o2 sensor i got some 18 ga wire (grn/blk/whi) ran it from the o2 sensor through a factory quick connect plug and to the conversion harness.
http://www.knology.net/~jediklc/D.htm
goto how to on the left and then OBD0 - OBD1
should help..
if you have an LS motor i'd use an LS distributor.. but that's just my opinion, others may say diffrent
should help..
JusT a Cx
14
Apr 28, 2004 09:17 AM
Ruby Civic
Oct 19, 2003 07:51 AM
