Brake Hose Routing
Old Jan 29, 2006 | 05:19 PM
PhatBoy5015's Avatar
Default Brake Hose Routing
I just wanted to see how yall routed your brake hoses. These are Goodridge Stainless Steel brake lines for a 99-00 SI. I have a rear disc conversion from a 92 Integra on my 97 HX, so I figured this would be the correct set. But when I jack up the rear of the car, the brake lines get a little tighter than I would like. I was thinking about grinding down the caliper so I could turn the bend the other way. Just wanted yall's opinion before I did anything. Sorry for the big pics.
Old Jan 30, 2006 | 08:28 AM
Default Re: Brake Hose Routing (PhatBoy5015)
Ok. I guess I'll just wait till I'm off again and grind down the caliper a little bit with a dremel.
Old Jan 30, 2006 | 08:57 AM
Luserkid's Avatar
We used brake lines from a 92 integra and they fit perfect. 96 coupe with 92 rear disc.
Old Jan 30, 2006 | 12:14 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Brake Hose Routing (Luserkid)
With my stainless lines, they didnt fit perfectly either. But I ran the banjo side of the line through those two tabs, and its 180% of how you have it (other side of the round connector. Also, I ran mine around the shock. If the line is stubborn, take a regular open end wrench and turn the part of the hose where it goes to the car's hardline and the whole line rotates sort of.
redboost10
Suspension & Brakes
Oct 30, 2008 08:55 AM
813EK
Jan 22, 2008 08:02 AM
JDM B16 EK
Mar 20, 2005 01:49 PM
neoboi
Jul 7, 2003 07:57 AM
