loose steering wheel????
Old Jan 29, 2006 | 02:20 PM
schardbody's Avatar
Default loose steering wheel????
whats up everyone, my 92 vx has a problem, the steering wheel wiggles almost like its not tight. i would take it all apart and check it out, but im worried about the SRS. i know on the older GMs there a bushing in the column that wears causing the wheel to get loose, is there something similar on the civics, or should i start looking for a whole new column??? Thanks in advance.
Old Jan 29, 2006 | 07:19 PM
aF's Avatar
aF
Default Re: loose steering wheel???? (schardbody)
the nut might have came loose.Just unhook your battery and take the two torque head bolts loose and remove the bag.There is a 19mm nut.Try to tighten it.If that isn't it,check the four 12mm bolts that hold the column to the dash frame.MAKE SURE YOU UNHOOK YOUR BATTERY BEFORE YOU UNPLUG YOUR AIRBAG OR THE SRS LIGHT WILL COME ON AND THE SRS SYSTEM WILL BE DISABLED!!YOU DON"T REALLY HAVE TO UNPLUG THE AIR BAG ONCE YOU HAVE UNBOLTED IT,JUST HOLD IT AWAY ENOUGH TO TIGHTEN THE NUT(IF IT IS LOOSE).
Old Jan 29, 2006 | 07:34 PM
schardbody's Avatar
i figured as long as i disconnected the battery it would be fine. i know the column is tight, i can actually wiggle the wheel without wiggling the column. its annoying.
Old Jan 29, 2006 | 07:45 PM
Sliced Beard's Avatar
Default Re: (schardbody)
what color is your steering wheel, I may have one for you since you are local.....
Old Jan 30, 2006 | 04:40 AM
schardbody's Avatar
my interior is blue, but i would need the whole column, not just the wheel.
Old Jan 30, 2006 | 07:03 AM
monicle's Avatar
its either going to be the nut that holds the steering whele on or the bolts on the joint that connect your steering column to the steering rack. depends on what your definition of "wiggle" is. either way checking either will not affect your srs so long as you dont turn your car on with your airbag not attached.
Old Jan 30, 2006 | 08:30 AM
schardbody's Avatar
thanks for all the input. when i say wiggle, i mean i can actually wiggle the wheel up down side to side like 1/4". if it were the joint between the rack and column the steering wheel wouldnt wiggle, it would be tight, but the steering would feel loose, this is actually just the wheel itself wiggling.
Old Jan 30, 2006 | 08:41 AM
monicle's Avatar
ah yes indeed. its going to be the nut that holds the wheel to the shaft. just pop your airbag off and tighten it down.
Old Jan 30, 2006 | 01:34 PM
schardbody's Avatar
thanks guys problem fixed, the nut holding the wheel on was loose.
niceprelude
Dec 11, 2008 05:05 AM
spooneg8
Dec 18, 2006 12:58 AM
CD8coupeSiR
Jun 21, 2006 10:18 PM
Hatch It
Jun 3, 2005 10:56 AM
GReddyTurboCoupe
May 23, 2005 01:44 PM
