Light weight the OEM flywheel!
I don't think you can, but if you can, its not worth it. Exedy flywheels are not that expensive. Or find a used ITR (if you're B-series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">I don't think you can, but if you can, its not worth it. Exedy flywheels are not that expensive. Or find a used ITR (if you're B-series)</TD></TR></TABLE>
i'm using a D series
D16y8
D16y8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">just buy an aftermarket light weight flywheel, taking so much material off your oem piece to make it lighter isn't a good idea, </TD></TR></TABLE>
Thnx
Thnx
I got the exedy lightweight, it was worth it. The car revs at least twice as fast as my friends stock. Its close to a bike, but not that close.
you can lighten the stock flywheel it just need to be balanced afterwards, usually holes arent drilled it is put on a lathe like platform and thenmetal is taken off in a circular pattern
yellowturbo
Nov 21, 2005 09:38 AM
deftones0817
21
Jan 22, 2003 10:51 AM
