A nut on my valvecover wont come off!
same problem here, you need to get the part of the bolt that is stuck into the valve cover. as for taking the nut off, I think theres gonna be some cutting needed. an Idea I have is to slice horizontally. then stick something in the center of the bolt while turning the nut with a wrench. my mechanic quoted $40 to fix it.
just break it off......the stud in question is only 6mm in diameter of which two mm's are threads.......don't be a wussy. if you have to, get a big pair of vice grips and grab on and turn firmly and await it to wring off. Once you have the valve cover removed, get a 10mm deep well socket and remove the stud from the head and replace with a decent used one or a new one. Problem solved.
lilxvtecxpwr
Aug 2, 2002 11:18 PM
