*HELP speedometer stopped working after swap....
Old Jan 29, 2006 | 12:27 AM
jdmpremonition's Avatar
Default *HELP speedometer stopped working after swap....
when i took my car out for the first time after the swap the speedometer worked fine, then it went crazy and now it's dead... along with my trip meter and odometer... the swap was OBD1 to OBD1, could it just be a fuse?
Old Jan 29, 2006 | 02:05 AM
BlueIntegraBoy's Avatar
Default Re: *HELP speedometer stopped working after swap.... (jdmpremonition)
Check your VSS
Old Jan 29, 2006 | 04:54 AM
THC07's Avatar
Default Re: *HELP speedometer stopped working after swap.... (BlueIntegraBoy)
What he said
Old Jan 29, 2006 | 05:12 AM
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpremonition &raquo;</TD></TR><TR><TD CLASS="quote">when i took my car out for the first time after the swap the speedometer worked fine, then it went crazy and now it's dead... along with my trip meter and odometer... the swap was OBD1 to OBD1, could it just be a fuse? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Check your VSS</TD></TR></TABLE>
your welcome.
Old Jan 29, 2006 | 06:27 AM
Syndacate's Avatar
Umm...
Not that I don't agree with these guys that the VSS should definately be checked out...but what is it? What kinda swap is from, and what is it into (year, model trim, etc.).
Old Jan 29, 2006 | 09:22 PM
thats the vehicle speed sensor right? and its located on the tranny? i swapped a 94 gsr into a 93 cx hatch...
Old Jan 29, 2006 | 09:27 PM
kyorishin's Avatar
first check ur vss...then if its not that then its possibly a loose wire in ur cluster or a lose ground wire somewhere
Old Jan 29, 2006 | 09:29 PM
riceburnerryan's Avatar
after checking the VSS i agree with kyorishin ... check the grounds as well ...
Old Jan 30, 2006 | 11:43 AM
check the vss as in see if its connected? and it also sometimes moves a little when i really gas it.
Old Jan 30, 2006 | 11:54 AM
ekcivic9's Avatar
is it the correct vss? i think some have 2 bolts and some have 3
Old Jan 30, 2006 | 12:44 PM
saywhat's Avatar
Default Re: (ekcivic9)
Also if you cut the VTEC plugs off the main harness to wire independently you might have cut the ground that the VSS and VTEC share.
Old Jan 31, 2006 | 12:58 AM
Default Re: (saywhat)
holy **** dude does that mean that's why my vtec wasn't working?...no wonder..... o man so what do i do to fix this just wire a ground to them both?
Old Jan 31, 2006 | 12:15 PM
ok i guess i wasnt getting a good enough ground to both my vss and my vtec wiring, cause i just moved around the wire that is the ground and now my vtak is crackin yo and my speedo is working. thanks everyone for your help.
Old Jan 31, 2006 | 12:37 PM
saywhat's Avatar
Default Re: (jdmpremonition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpremonition &raquo;</TD></TR><TR><TD CLASS="quote">ok i guess i wasnt getting a good enough ground to both my vss and my vtec wiring, cause i just moved around the wire that is the ground and now my vtak is crackin yo and my speedo is working. thanks everyone for your help. </TD></TR></TABLE>
Yea! do I get a cookie? Seriously good to hear it is working now.
Old Jan 31, 2006 | 06:19 PM
shyt.... it stopped working again today, and i only got to drive with vtec for 17 miles!!!... i have no idea what it could be. the way i fixed it the first time is i just started moving around the wires to the vss and some other wires and it worked. then i went to take my friend for a ride and shifted hard to second (1st hit vtec) then it just didnt work in 2nd. i think when i shifted i jerked something loose that i fixed earlier when i messed with the wires, but idk.... oh yeah and we re-wired all of the wires from vtec pressure, vtec and the knock sensor, back into the ecu. i was thinking it has something to do with the ground because both vtec and the vss isnt working, but all of them are good. any help would be appreciated.
Old Jan 31, 2006 | 08:52 PM
saywhat's Avatar
I would just carefully cut into the harness extend the grounds crimp on a ring terminal and ground it somewhere, rather then hunt down the break in the wiring.
Old Feb 1, 2006 | 02:33 AM
so u think its a break in the wiring? but where's the break? i believe we wired a seperate ground to both the vtech and vss...
Old Feb 1, 2006 | 07:42 AM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpremonition &raquo;</TD></TR><TR><TD CLASS="quote">so u think its a break in the wiring? but where's the break? i believe we wired a seperate ground to both the vtech and vss...</TD></TR></TABLE> Well if you already did separate grounds I don't know what to tell you.
Old Feb 1, 2006 | 01:02 PM
ok thanks anyways...
Old Feb 2, 2006 | 12:52 AM
can anyone help? what are the two sets of two wires coming from the vss? could my vss possibly be bad and that is affecting my vtec? someone help please!!
Old Feb 2, 2006 | 01:03 AM
db8SI's Avatar
hey bro i have the same problem but i didnt do a swap i got the car like that ... i can heear VTEC on mine jst no speedo
common someone help
Old Feb 2, 2006 | 10:15 AM
you guys can buy my rev speed meter
Old Feb 2, 2006 | 01:49 PM
snowblind7x's Avatar
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">you guys can buy my rev speed meter </TD></TR></TABLE>
that still wont fix vtec tho....
Old Feb 3, 2006 | 12:16 PM
Default Re: *HELP speedometer stopped working after swap.... (db8SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8SI &raquo;</TD></TR><TR><TD CLASS="quote">hey bro i have the same problem but i didnt do a swap i got the car like that ... i can heear VTEC on mine jst no speedo
common someone help </TD></TR></TABLE>
this has something to do with your vss (vehicle speed sensor) its located on top of your tranny, check the ground to it.
Old Feb 3, 2006 | 02:02 PM
T-RO's Avatar
ive got a VSS for sale on ebay if you need one.
GroundAssault
Apr 1, 2007 09:48 AM
EViLSTAR
14
Oct 23, 2006 05:32 PM
==Catfish==
Mar 24, 2005 11:08 AM
mister_r0b
Mar 7, 2004 09:43 PM
Blackhatch94
Nov 12, 2003 06:10 PM
