throwing a code 9?
Old Jan 28, 2006 | 09:47 PM
cmyrex's Avatar
Default throwing a code 9?
i know this is cylinder position senser is this a normal thing to happen when doing a dp to mp? the motor ran fine b4 any suggestions would be great thx
Old Jan 28, 2006 | 11:01 PM
.Manny.'s Avatar
Touching My Member
is yur timing dead on?? I had that same problem when my exhaust cam was off just one tooth. fix timing and it should go away
Old Jan 28, 2006 | 11:02 PM
court's Avatar
25 Year Member
Default Re: throwing a code 9? (cmyrex)
you either have the c1/c2 mixed up, up the cyp in the dizzy is bad
Old Jan 29, 2006 | 09:33 AM
cmyrex's Avatar
Default Re: throwing a code 9? (court)
so it i flip c1/c2 it should be cool?
Old Jan 29, 2006 | 10:13 AM
court's Avatar
25 Year Member
try it, if it doesnt work, then you might have malfunctioning cyps , or a faulity dist bearing
Old Jan 29, 2006 | 10:38 AM
cmyrex's Avatar
ill give it a shot ty for the help!
Old Jan 29, 2006 | 11:56 AM
cmyrex's Avatar
i changed c1/c2 but still a code 9
Old Jan 29, 2006 | 05:47 PM
court's Avatar
25 Year Member
A: you have c1/c2 osilated andconnected properly using soldering iron
B: your connection to at the distributor pin is correct, if soldered on, is it done correctly.
C: if thoose check out, then the two pins blue/green blue/yellow are mixed backwards
D: if thoose are good, then the sensor inside the dizzy is bad
if you need one, hit me up, i have some spare dizzy parts (obd1/2)
blasterman87
22
Sep 25, 2009 07:50 AM
juan400hp
Aug 20, 2009 08:11 PM
ef_zc
Aug 12, 2008 06:04 PM
Cereal_Killer
Jan 25, 2002 01:52 PM
wuhungsixxx
Oct 24, 2001 10:20 AM
